Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
Computer will not power on
The laptop will not respond or show any sign of powering up
Faulty Power Adapter
Ensure the power adapter is plugged in and the charge light is on. If the light is not on, and the adapter is plugged in, the adapter is faulty. Consider purchasing a replacement adapter.
Faulty Battery
If the power adapter is plugged in, and the light on the adapter is on, make sure the adapter is connect to the laptop. If the laptop only powers up when the adapter is plugged in, regardless of charging time, then the battery is faulty. Replace the battery using our battery replacement guide.
Motherboard is Faulty
The Kindle is a relatively simple device in that it does not contain many components. Through process of elimination, faulty parts can be narrowed down easily. If the Kindle does not turn on after the previous steps, it is likely that the motherboard needs to be replaced.
Keyboard not Responding
The keys on your keyboard won't respond or appear to be broken
Faulty Keyboard
If the entire keyboard fails to respond, try replacing it with our keyboard replacement guide.
Unresponsive Touchscreen
The monitor on your Inspiron 7568 does not respond to touch and display remains the same.
Outdated Display Driver
Use Dell's "Detect PC" tool here. Select "Drivers & Downloads" and ensure that your touch drivers are up to date.
Defective Display
If updating your drivers does not restore touch functionality, it is possible that the display assembly needs to be replaced.
Device is Overheating
While you are working, your computer randomly shuts off without notification.
Dust in Vents or Fans
Computers can overheat due to excessive dust and other materials stuck in the vents or fan. To fix this, use a compressed air duster to carefully blow the dust off the vents and fan.
Faulty Fan
If the fan shows no sign of turning on when the computer is powered on, you may need to replace it.
Touchpad not working/Frozen mouse
Author
with
Richard
36,411 Reputation
11 Guides authored
1 Comment
This unit has always been a severe problem.
I cannot even DOWNLOAD a new windows 10 …
The laptop says. X No bootable devices found.
A while back I refused to continue update downloads…the laptop was getting worse…especially after a warranty technician changed a hard drive.
I bout give up on Windows 10…
Now I have purchased a new hard drive again….a and I had to buy a new windows 10
that will not DOWNLOAD.
No driver's…
mohawkmine - Reply Share
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 13
All Time: 1,941
