Up to 20% off select tools
Dell Inspiron 7568 Display Assembly Replacement Guide
Views: 1.6K
View statistics:
Past 24 Hours:
6
Past 7 Days:
20
Past 30 Days:
78
All Time:
1,592
Comments: 0
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 2
2 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 10 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
By following the steps in this guide one should be able to replace the complete display assembly on the a Dell Inspiron 7568.
    1. Dell Inspiron 7568 Display Assembly Replacement Guide, Battery: step 1, image 1 of 2 Dell Inspiron 7568 Display Assembly Replacement Guide, Battery: step 1, image 2 of 2
      • Remove the ten 7mm Phillips #1 screws on the bottom cover.
      • Remove the bottom cover.
      Ask FixBot
    2. Dell Inspiron 7568 Display Assembly Replacement Guide: step 2, image 1 of 2 Dell Inspiron 7568 Display Assembly Replacement Guide: step 2, image 2 of 2
      • Remove the four 3mm Phillips #1 screws holding the battery.
      • Unhinge the connector cable to the battery.
      • Remove the battery.
      Ask FixBot
    1. Dell Inspiron 7568 Display Assembly Replacement Guide, Display Assembly: step 3, image 1 of 2 Dell Inspiron 7568 Display Assembly Replacement Guide, Display Assembly: step 3, image 2 of 2
      • Unscrew & remove the two 3mm screws (using a ph1 screwdriver bit) and the cable bracket, above the motherboard
      • Doing this will allow one to access the LCD-motherboard connector cables.
      Ask FixBot
    2. Dell Inspiron 7568 Display Assembly Replacement Guide: step 4, image 1 of 2 Dell Inspiron 7568 Display Assembly Replacement Guide: step 4, image 2 of 2
      • Unscrew the 7mm screws that secure the left and right hinges (using a ph1 screwdriver bit).
      Ask FixBot
    3. Dell Inspiron 7568 Display Assembly Replacement Guide: step 5, image 1 of 3 Dell Inspiron 7568 Display Assembly Replacement Guide: step 5, image 2 of 3 Dell Inspiron 7568 Display Assembly Replacement Guide: step 5, image 3 of 3
      • Disconnect the antenna cable (under the left hinge)
      • Disconnect the LCD and Touchscreen display cables under the right hinge.
      • These are a set of two cables. For better image see image two in step one of this guide.
      Ask FixBot
    4. Dell Inspiron 7568 Display Assembly Replacement Guide: step 6, image 1 of 1
      • Carefully separate the screen from the bottom half of the device.
      Ask FixBot
2 other people completed this guide.
Author
with
Yash Samant
406 Reputation
3 Guides authored
USF Tampa, Team S2-G2, Lacy Spring 2017 Member of USF Tampa, Team S2-G2, Lacy Spring 2017
USFT-LACY-S17S2G2
4 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 6
Past 7 Days: 20
Past 30 Days: 78
All Time: 1,592
