Dell Inspiron 7568 Battery Replacement Guide
    1. Dell Inspiron 7568 Battery Replacement Guide, Battery: step 1, image 1 of 2 Dell Inspiron 7568 Battery Replacement Guide, Battery: step 1, image 2 of 2
      • Remove the ten 7mm Phillips #1 screws on the bottom cover.
      • Remove the bottom cover.
      Ask FixBot
    2. Dell Inspiron 7568 Battery Replacement Guide: step 2, image 1 of 2 Dell Inspiron 7568 Battery Replacement Guide: step 2, image 2 of 2
      • Remove the four 3mm Phillips #1 screws holding the battery.
      • Unhinge the connector cable to the battery.
      • Remove the battery.
      Ask FixBot
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
For optimal performance, calibrate your newly installed battery after completing this guide.
5 other people completed this guide.
Luis Velez
452 Reputation
2 Guides authored
USF Tampa, Team S2-G2, Lacy Spring 2017 Member of USF Tampa, Team S2-G2, Lacy Spring 2017
USFT-LACY-S17S2G2
4 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 24
Past 30 Days: 101
All Time: 1,683
