Screen not displaying correctly
The screen is either cracked, scratched or completely dark.
Screen turned off or showing as just a black display
Before deciding that you need to replace the screen or the laptop, check to see if you have disabled your display, then locate the "Fn" and the "F1" key. By pressing and holding the "Fn" key and tapping the "F1" you will cycle through your laptops display options. Wait a few seconds between each tap of the "F1" key for the display to come back, if it doesn't... read on.
Drained battery / No power
Check to make sure either your laptop has a charge or is plugged into the wall.
Damaged or broken screen
If the above solutions did not work or your screen has cracks or scratches that are causing you issues, then it is more than likely time to replace your screen. You can follow our repair guide.
Computer running slow
Your computer is slow to respond to your commands, its downloads aren’t running smoothly or your movie is experiencing lag.
Too many programs open
Every computer has its limits. Before you blame the computer for running slow, check to see how many programs you have open. If you have some that you aren’t using, then speeding up your computer could be as simple as closing out of that game of solitaire or closing the browser tabs you are no longer using.
Stored data retrieval slow
When a computer stores data, it puts it away wherever it can find space. To solve the slowness, sometimes all a computer needs is a reboot to get a chance to reorganize its data.
Virus or Malware present
Viruses and malware are two major issues when it comes to the health and performance of your laptop. Running a virus scan couldn’t hurt; try using programs like Zonealarm or Norton to identify any possible issues and make sure they are dealt with.
Reached the limits of available RAM
If you’ve gone through all of the above solutions and the issue persists, then it is time to upgrade your computers RAM. You can go online or to your local computer parts store and have them help you select the best compatible RAM for your laptop. Then we can help you remove the old RAM and insert the upgrade with this guide.
Battery not holding charge
Your laptop seems to be dying more often than it used to, or maybe that battery warning is appearing just after you unplug it; there are a couple of potential issues here.
Computer is overheating
Your computer may be overheating due to an accumulation of dust in the computers vents or fans. To fix this issue, use a can of compressed air to blow the dust off of your fan through the vents on the computer.
Charging cable is either shorting, burnt out, or is broken
The battery may not be holding a charge due to a broken or malfunctioning charging cable. If this is the case, you will need to buy a new charging cable.
Computer only working when plugged in to wall
If your computer is only working when it is plugged into the wall, this may be due to a defective battery. In which case you will need to purchase a new battery for your computer, and we can it show you how to install.
CD/DVD's not playing
Your Dell Inspiron 3520 is not playing CD’s or DVD’s
Scratched disk
Check to see if the CD or DVD has a scratch. If so, this could be the reason the disk isn’t playing.
Dust on CD / optical drive
Your Dell Inspiron 3520 may not be playing CD/DVD’s due to dust on the disk or optical drive. In this case, use a soft cloth to wipe the disk, being careful not to scratch it. Then use a can of compressed air to blow any dust out of the CD drive.
Faulty optical drive
If the above actions do not fix your problem, you may need to replace the optical drive.
Keys on keyboard not typing
Keys on keyboard are not registering or are missing
Keys are missing
If you can see that a certain key is missing, you will need to replace the keyboard.
Keys aren’t registering
Keys not registering may be due to the keyboard being disconnected or broken. This would require you to replace the keyboard.
Ian
1,638 Reputation
5 Guides authored
USF Tampa, Team 16-2, Watkins Winter 2015 Member of USF Tampa, Team 16-2, Watkins Winter 2015
USFT-WATKINS-W15S16G2
3 Members
60 Guides authored
5 Comments
When I was plug the charger ...chargeing indication off in charger .....what is the solution.....
Marjokk - Reply Share
I get 7 beeps at startup. On a Dell Inspiron 3520. What needed to be fixed the processor or the mother board???
Wally D. Freimanis - Reply Share
While in the middle of a zoom session microphone and speakers died.
Cannot recover from this problem - any thoughts?
Methuselah _4838 - Reply Share
Battery charging temporarily disabled .
Lori - Reply Share
How to reset password?
Sandile Mcdonald - Reply Share
Past 24 Hours: 2
Past 7 Days: 16
Past 30 Days: 57
All Time: 5,818
