Dell Inspiron 3520 Keyboard Replacement
    1. Dell Inspiron 3520 Keyboard Replacement, Battery: step 1, image 1 of 2 Dell Inspiron 3520 Keyboard Replacement, Battery: step 1, image 2 of 2
      • Turn off notebook
      • Set the notebook upside down with the battery facing away from you.
      • Locate the unlock and release sliding tabs on the bottom right and left hand corners of the battery respectively.
      Ask FixBot
    2. Dell Inspiron 3520 Keyboard Replacement: step 2, image 1 of 3 Dell Inspiron 3520 Keyboard Replacement: step 2, image 2 of 3 Dell Inspiron 3520 Keyboard Replacement: step 2, image 3 of 3
      • Slide the right tab to the right to unlock the battery.
      • Slide and hold the the left tab to the left to release the battery from the unit.
      • Finally, remove the battery by sliding it away from the unit and yourself.
      Ask FixBot
    1. Dell Inspiron 3520 Keyboard Replacement, Keyboard: step 3, image 1 of 2 Dell Inspiron 3520 Keyboard Replacement, Keyboard: step 3, image 2 of 2
      • Locate the four tabs along the top edge of the keyboard.
      • Using the spudger, push the tabs away from the keyboard and pull the keyboard up away from the laptop.
      Ask FixBot
    2. Dell Inspiron 3520 Keyboard Replacement: step 4, image 1 of 1
      • Slide the keyboard forward towards the screen to release the bottom tabs.
      Ask FixBot
    3. Dell Inspiron 3520 Keyboard Replacement: step 5, image 1 of 2 Dell Inspiron 3520 Keyboard Replacement: step 5, image 2 of 2
      • Carefully lift the board up and locate the connecting cable.
      • Gently pull the end of the cable free from the port on the laptop.
      Ask FixBot
7 other people completed this guide.
Ian
1,638 Reputation
5 Guides authored
USF Tampa, Team 16-2, Watkins Winter 2015 Member of USF Tampa, Team 16-2, Watkins Winter 2015
USFT-WATKINS-W15S16G2
3 Members
60 Guides authored
1 Guide Comment
Hi, any ideas why a NEW keyboard still wouldn't work after installing it? The ribbon was connected properly, it’s the right keyboard, and I made sure the driver was updated. Any help would be greatly appreciated. Started a new job and my keyboard went to $@$* in the first week. Can’t really afford to buy a new laptop this weekend. It works with an external USB keyboard so it’s probably not a software issue… I think?
Alittle advice would be greatly appreciated. Thanks!
Stumpedu - Reply Share
Past 24 Hours: 6
Past 7 Days: 38
Past 30 Days: 174
All Time: 7,503
