Dell Inspiron 3520 Screen Replacement
    1. Dell Inspiron 3520 Screen Replacement, Battery: step 1, image 1 of 2 Dell Inspiron 3520 Screen Replacement, Battery: step 1, image 2 of 2
      • Turn off notebook
      • Set the notebook upside down with the battery facing away from you.
      • Locate the unlock and release sliding tabs on the bottom right and left hand corners of the battery respectively.
      Ask FixBot
    2. Dell Inspiron 3520 Screen Replacement: step 2, image 1 of 3 Dell Inspiron 3520 Screen Replacement: step 2, image 2 of 3 Dell Inspiron 3520 Screen Replacement: step 2, image 3 of 3
      • Slide the right tab to the right to unlock the battery.
      • Slide and hold the the left tab to the left to release the battery from the unit.
      • Finally, remove the battery by sliding it away from the unit and yourself.
      Ask FixBot
    1. Dell Inspiron 3520 Screen Replacement, Keyboard: step 3, image 1 of 2 Dell Inspiron 3520 Screen Replacement, Keyboard: step 3, image 2 of 2
      • Locate the four tabs along the top edge of the keyboard.
      • Using the spudger, push the tabs away from the keyboard and pull the keyboard up away from the laptop.
      Ask FixBot
    2. Dell Inspiron 3520 Screen Replacement: step 4, image 1 of 1
      • Slide the keyboard forward towards the screen to release the bottom tabs.
      Ask FixBot
    3. Dell Inspiron 3520 Screen Replacement: step 5, image 1 of 2 Dell Inspiron 3520 Screen Replacement: step 5, image 2 of 2
      • Carefully lift the board up and locate the connecting cable.
      • Gently pull the end of the cable free from the port on the laptop.
      Ask FixBot
    1. Dell Inspiron 3520 Screen Replacement, Screen: step 6, image 1 of 3 Dell Inspiron 3520 Screen Replacement, Screen: step 6, image 2 of 3 Dell Inspiron 3520 Screen Replacement, Screen: step 6, image 3 of 3
      • Locate and remove the 14 (5mm) Phillips #00 screws from the bottom of the laptop.
      • Locate and remove the two 5mm Phillips #00 screws found under the keyboard.
      • Disconnect the two controlling wires with the blue pull tabs.
      Ask FixBot
    2. Dell Inspiron 3520 Screen Replacement: step 7, image 1 of 3 Dell Inspiron 3520 Screen Replacement: step 7, image 2 of 3 Dell Inspiron 3520 Screen Replacement: step 7, image 3 of 3
      • Using the spudger, carefully work your way around the edge of the upper shell.
      • Lift the upper shell away from the laptop.
      • Close the laptop and remove the casing over the hinge using the spudger.
      Ask FixBot
    3. Dell Inspiron 3520 Screen Replacement: step 8, image 1 of 3 Dell Inspiron 3520 Screen Replacement: step 8, image 2 of 3 Dell Inspiron 3520 Screen Replacement: step 8, image 3 of 3
      • Gently pull the cable located near the fan free from its dock.
      • Just behind the optical drive locate the 4mm Phillps #00 mounting screw for the small circuit board and remove it.
      • The board should then pull free.
      • Take note of how the cables fit along the ridge for when it comes to reassembly.
      Ask FixBot
    4. Dell Inspiron 3520 Screen Replacement: step 9, image 1 of 2 Dell Inspiron 3520 Screen Replacement: step 9, image 2 of 2
      • Open the laptop and locate the two hinges.
      • Each hinge has two 5mm Phillips #00 screws that need to be removed.
      • With the screws removed the screen should pull free.
      Ask FixBot
6 other people completed this guide.
Ian
1,638 Reputation
5 Guides authored
USF Tampa, Team 16-2, Watkins Winter 2015 Member of USF Tampa, Team 16-2, Watkins Winter 2015
USFT-WATKINS-W15S16G2
3 Members
60 Guides authored
1 Guide Comment
These instructions are not for screen replacement
Ryan Zulu - Reply Share
Past 24 Hours: 4
Past 7 Days: 41
Past 30 Days: 163
All Time: 7,409
