Up to 20% off select tools
Dell Inspiron 3520 RAM Replacement
Views: 34K
View statistics:
Past 24 Hours:
6
Past 7 Days:
28
Past 30 Days:
128
All Time:
34,130
Comments: 0
Go to guide comments
Completed: 18
18 people have marked this guide "completed." Will you be next?
Favorites: 4
4 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 10 minutes
Difficulty: Easy
Parts
Tools
  • Spudger
    4.9
Introduction
Go to step 1 ↓
This repair process involves going into the computer, therefore,you will need to be gentle with electronic components. Also, consider working on this repair in a clean environment so no small pieces of the computer are lost.
    1. Dell Inspiron 3520 RAM Replacement, Battery: step 1, image 1 of 2 Dell Inspiron 3520 RAM Replacement, Battery: step 1, image 2 of 2
      • Turn off notebook
      • Set the notebook upside down with the battery facing away from you.
      • Locate the unlock and release sliding tabs on the bottom right and left hand corners of the battery respectively.
      Ask FixBot
    2. Dell Inspiron 3520 RAM Replacement: step 2, image 1 of 3 Dell Inspiron 3520 RAM Replacement: step 2, image 2 of 3 Dell Inspiron 3520 RAM Replacement: step 2, image 3 of 3
      • Slide the right tab to the right to unlock the battery.
      • Slide and hold the the left tab to the left to release the battery from the unit.
      • Finally, remove the battery by sliding it away from the unit and yourself.
      Ask FixBot
    1. Dell Inspiron 3520 RAM Replacement, Keyboard: step 3, image 1 of 2 Dell Inspiron 3520 RAM Replacement, Keyboard: step 3, image 2 of 2
      • Locate the four tabs along the top edge of the keyboard.
      • Using the spudger, push the tabs away from the keyboard and pull the keyboard up away from the laptop.
      Ask FixBot
    2. Dell Inspiron 3520 RAM Replacement: step 4, image 1 of 1
      • Slide the keyboard forward towards the screen to release the bottom tabs.
      Ask FixBot
    3. Dell Inspiron 3520 RAM Replacement: step 5, image 1 of 2 Dell Inspiron 3520 RAM Replacement: step 5, image 2 of 2
      • Carefully lift the board up and locate the connecting cable.
      • Gently pull the end of the cable free from the port on the laptop.
      Ask FixBot
    1. Dell Inspiron 3520 RAM Replacement, RAM: step 6, image 1 of 1
      • Locate the RAM chip(s)
      • There are no RAM chips present in this photo.
      Ask FixBot
    2. Dell Inspiron 3520 RAM Replacement: step 7, image 1 of 2 Dell Inspiron 3520 RAM Replacement: step 7, image 2 of 2
      • There are two connecting pins for the lower chip.
      • There are two connecting pins for the upper chip.
      • Pull the pins away from the sides of the chip(s) to release it.
      • The chip(s) should slide away from the dock easily.
      Ask FixBot
18 other people completed this guide.
Author
with
Ian
1,638 Reputation
5 Guides authored
USF Tampa, Team 16-2, Watkins Winter 2015 Member of USF Tampa, Team 16-2, Watkins Winter 2015
USFT-WATKINS-W15S16G2
3 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 6
Past 7 Days: 28
Past 30 Days: 128
All Time: 34,130
