Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
Cannot hear anything from the speakers
No audio is coming from the speakers
Faulty audio driver
If you experience no audio from the laptop’s speakers, then the problem could be caused by your audio driver failing to respond. To fix this problem, you simply need to update your audio driver by going to Intel’s website. Make sure to choose a driver that is compatible with the laptop’s version of Windows.
Cannot see anything in the display
The screen is not showing an image even though the laptop is turned on
Faulty video driver
If your laptop’s screen isn’t responding, then the problem could be caused by your video driver failing to respond. To fix this problem, you simply need to update your video driver by going to Intel’s website. Make sure to choose a driver that is compatible with the laptop’s version of Windows.
Broken display
If the above doesn’t work, then the display may be broken. You can fix the display yourself by following this handy guide.
Cannot boot up the device
The laptop will not power up
Broken battery
If the laptop won’t turn on, then your issue may be that your battery has melted and is no longer able to properly function. To fix this, replace the battery with a new one that’ll properly charge and fit your device.
Broken hard drive
If replacing the battery doesn’t work, your hard drive may have failed. Replace the hard drive following this helpful guide.
The device is overheating
The laptop is becoming hot and turning off by itself
Dust clogging the device
If your laptop is overheating, the problem may be due to dust clogging it. To remove the dust, use a cotton swab to clean out the laptop’s fan, and use compressed air to blow the dust out of your keyboard.
Unable to connect to Wifi
The laptop cannot find wireless networks or is unable to connect to them
Faulty wireless card driver
If you are unable to connect to the internet wirelessly, the problem could be caused by a malfunctioning driver for your wireless card. To check the model of your wireless card, open up the start screen in Windows and go to settings. Right click on Wireless Network Connection and click on properties to open up a window that displays information about your card. Visit this link and search for the appropriate driver to download.
Broken wireless card
If updating the driver doesn’t work, your wireless network card may have failed. Replace it using this guide.
The keyboard is not working
One or more keys on the keyboard are not functioning properly
Debris under the keys
An individual key might not be working properly due to there being something wedged inside the keycap and blocking it. To clean the keyboard, moisten a soft cloth with water and wipe it. Be sure to disconnect any power connections to your computer and remove the battery before beginning. In addition to this, compressed air can be used to blow away any dust that might be trapped underneath the key.
Broken keyboard
If one or more keys still don’t work after cleaning the keyboard, replace the keyboard using this guide.
Luc-Anthony Breneville
183 Reputation
1 Guide authored
1 Comment
Getting message at boot up battery not identified, will not take charge press any key to continue
Diana - Reply Share
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 37
All Time: 1,302
