Dell Inspiron 1501 Keyboard Replacement
    1. Dell Inspiron 1501 Keyboard Replacement, Battery: step 1, image 1 of 3 Dell Inspiron 1501 Keyboard Replacement, Battery: step 1, image 2 of 3 Dell Inspiron 1501 Keyboard Replacement, Battery: step 1, image 3 of 3
      • Place the laptop facedown with the battery facing you.
      • Push the switch above the battery to the right and hold it in that position.
      • Lift the battery using the grip on the top and remove it from its socket.
      Ask FixBot
    1. Dell Inspiron 1501 Keyboard Replacement, Hinge Cover: step 2, image 1 of 2 Dell Inspiron 1501 Keyboard Replacement, Hinge Cover: step 2, image 2 of 2
      • Open the laptop all the way, rotating the display so that it is level with the surface that you are working on.
      • Insert the spudger underneath the groove on the right side of the hinge cover.
      • Push up to pry the edge of the hinge cover out.
      • Lift up to release the hinge cover from the laptop, working from right to left.
      Ask FixBot
    1. Dell Inspiron 1501 Keyboard Replacement, Keyboard: step 3, image 1 of 3 Dell Inspiron 1501 Keyboard Replacement, Keyboard: step 3, image 2 of 3 Dell Inspiron 1501 Keyboard Replacement, Keyboard: step 3, image 3 of 3
      • Remove the two 5mm JIS #1 screws from the top of the keyboard.
      • Lift the top of the keyboard up and pull the keyboard away from the laptop.
      • Be sure not to break the ribbon connector that attaches the keyboard to the laptop.
      Ask FixBot
    2. Dell Inspiron 1501 Keyboard Replacement: step 4, image 1 of 2 Dell Inspiron 1501 Keyboard Replacement: step 4, image 2 of 2
      • Open the latch holding the ribbon from the top
      • Remove the keyboard from the laptop.
      Ask FixBot
2 other people completed this guide.
Don Dao
418 Reputation
4 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 18
Past 30 Days: 67
All Time: 1,152
