Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
Computer Won't Turn On
The computer shows no signs of life no matter how many times I press the button.
Power Source
Make sure the outlet your computer is plugged into is working. To test it, try plugging in another device such as a lamp into the outlet to make sure it works.
Broken Charger
If your computer won’t turn on, this could indicate the battery is drained. Ensure the charger is working first by plugging your computer in for several minutes before attempting to power on. Make sure there are no kinks, breaks or exposed wires. If there are, or if your device is still not turning on, you may have to buy a new charger.
Bad Battery
If your charger is working and your computer still won't turn on, there might be a problem with the battery. You can try to buy a new battery and replace it using this guide.
Keyboard/Keys Not Responding
The keys on your keyboard won't respond or appear to be broken or missing.
Keys Are Stuck In Place
If a key can't be pressed down, it may be blocked by debris. To fix this, remove the key and check if something is in the way. Most keys can be removed the by using the Metal Spudger found in the Pro Tech Toolkit, or another slim object, for leverage and simply pop off. Make sure to wipe off the area underneath. Once it is sufficiently clean, snap the key back into position.
Keys Are Missing
If keys on the keyboard are missing, replace them.
Faulty Keyboard
If multiple keys or the entire keyboard still fail to respond after the above steps, try replacing it entirely with this guide.
Internet is Slow or Not Connecting
My computer is having problems with its internet connection
Connecting to Insecure Network
Your laptop might not be getting a strong connection to the router or wifi network. Try moving closer to the internet source. You may need to consult your network administrator to make sure your connection is secure.
Wifi/Router Malfunctioning
The router or wifi network you are trying to access might be down or malfunctioning. You may need to call your internet provider.
Faulty Wifi Card Driver
If none of the above solutions solved your wifi issues, there might be an issue with your wifi card driver. Try to update or rollback your Network Adapter driver (Wifi Card driver).
Faulty Wifi Card
If your problem persists after all of the above steps, there might be an issue with your wifi card. Replace the wifi card using this guide.
Computer is Running Slowly
My computer is running slowly.
Overheating
Your computer may be overheating, which can severely slow down and damage your computer. If your computer is warm, turn off your computer and restart it after it has cooled down.
RAM Needs to be Upgraded
If your computer is running uncharacteristically slowly, you may be trying to run large programs that the computer's current RAM cannot handle. To fix this, you may need to remove and update your RAM. You can do this by following this guide.
Fan is bad
If your problem persists after attempting the above, there may be an issue with your computer's fan. You can remove the fan for cleaning, or replacement, by following this guide.
Distorted Audio
The sound from my computer is distorted.
Faulty Driver
The audio driver for your computer may be faulty or corrupt which can lead to issues with the sound. Reinstall your current drivers with clean copies.
Bad Speakers
If all else fails, consider replacing your speakers using this guide.
0 Comments
Past 24 Hours: 2
Past 7 Days: 10
Past 30 Days: 30
All Time: 706
