Dell Inspiron 15-7547 Battery Replacement
    1. Dell Inspiron 15-7547 Battery Replacement, Bottom Cover: step 1, image 1 of 1
      • Before you begin, be sure to turn off your laptop and unplug it from the outlet.
      • Close the display and flip the laptop on its back.
      • Loosen the ten 5.0 mm-long Phillips #0 screws.
      • The four screws marked with orange will remain captive to the cover.
      Ask FixBot
    2. Dell Inspiron 15-7547 Battery Replacement: step 2, image 1 of 1
      • Use a spudger to pry up and loosen the back cover.
      • Remove the back cover.
      Ask FixBot
    1. Dell Inspiron 15-7547 Battery Replacement, Battery: step 3, image 1 of 2 Dell Inspiron 15-7547 Battery Replacement, Battery: step 3, image 2 of 2
      • Remove the five 5.0 mm-long Philips #0 screws that connect the battery to the case.
      Ask FixBot
    2. Dell Inspiron 15-7547 Battery Replacement: step 4, image 1 of 2 Dell Inspiron 15-7547 Battery Replacement: step 4, image 2 of 2
      • Lift the battery out of the case.
      Ask FixBot
    3. Dell Inspiron 15-7547 Battery Replacement: step 5, image 1 of 3 Dell Inspiron 15-7547 Battery Replacement: step 5, image 2 of 3 Dell Inspiron 15-7547 Battery Replacement: step 5, image 3 of 3
      • Pull the battery cable's pull tab towards the battery to disconnect it from the motherboard.
      • Pull parallel to the motherboard, not straight up.
      • Most of the cable is attached to the case with adhesive, which may cause slight resistance.
      • Remove the battery.
      Ask FixBot
For optimal performance, after completing this guide, calibrate your newly installed battery.
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 7
Past 30 Days: 41
All Time: 2,654
