Dell Inspiron 15-7547 Keyboard Replacement
Views: 3.3K
View statistics:
Past 24 Hours:
2
Past 7 Days:
20
Past 30 Days:
79
All Time:
3,257
Comments: 3
2 comments on steps, 1 guide comment.
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 40 - 50 minutes
Difficulty: Difficult
Introduction
Go to step 1 ↓
This guide shows the process of removing the keyboard from the Dell Inspiron 15-7547.
Parts
Tools
    1. Dell Inspiron 15-7547 Keyboard Replacement, Bottom Cover: step 1, image 1 of 1
      • Before you begin, be sure to turn off your laptop and unplug it from the outlet.
      • Close the display and flip the laptop on its back.
      • Loosen the ten 5.0 mm-long Phillips #0 screws.
      • The four screws marked with orange will remain captive to the cover.
      Ask FixBot
    2. Dell Inspiron 15-7547 Keyboard Replacement: step 2, image 1 of 1
      • Use a spudger to pry up and loosen the back cover.
      • Remove the back cover.
      Ask FixBot
    1. Dell Inspiron 15-7547 Keyboard Replacement, Battery: step 3, image 1 of 2 Dell Inspiron 15-7547 Keyboard Replacement, Battery: step 3, image 2 of 2
      • Remove the five 5.0 mm-long Philips #0 screws that connect the battery to the case.
      Ask FixBot
    2. Dell Inspiron 15-7547 Keyboard Replacement: step 4, image 1 of 2 Dell Inspiron 15-7547 Keyboard Replacement: step 4, image 2 of 2
      • Lift the battery out of the case.
      Ask FixBot
    3. Dell Inspiron 15-7547 Keyboard Replacement: step 5, image 1 of 3 Dell Inspiron 15-7547 Keyboard Replacement: step 5, image 2 of 3 Dell Inspiron 15-7547 Keyboard Replacement: step 5, image 3 of 3
      • Pull the battery cable's pull tab towards the battery to disconnect it from the motherboard.
      • Pull parallel to the motherboard, not straight up.
      • Most of the cable is attached to the case with adhesive, which may cause slight resistance.
      • Remove the battery.
      Ask FixBot
    1. Dell Inspiron 15-7547 Keyboard Replacement, Hard Drive: step 6, image 1 of 2 Dell Inspiron 15-7547 Keyboard Replacement, Hard Drive: step 6, image 2 of 2
      • Remove the four 5.0 mm-long Philips #0 screws connecting the hard drive to the chassis.
      Ask FixBot
    2. Dell Inspiron 15-7547 Keyboard Replacement: step 7, image 1 of 2 Dell Inspiron 15-7547 Keyboard Replacement: step 7, image 2 of 2
      • Disconnect the hard drive from the motherboard by placing your fingers at the back, and pulling forward towards the front of the chassis.
      Ask FixBot
    3. Dell Inspiron 15-7547 Keyboard Replacement: step 8, image 1 of 1
      • Lift the hard drive out of the chassis.
      Ask FixBot
    1. Dell Inspiron 15-7547 Keyboard Replacement, WiFi Card: step 9, image 1 of 2 Dell Inspiron 15-7547 Keyboard Replacement, WiFi Card: step 9, image 2 of 2
      • Remove the 3.0 mm-long Philips #0 screw at the end of the Wifi-Card
      Ask FixBot
    2. Dell Inspiron 15-7547 Keyboard Replacement: step 10, image 1 of 2 Dell Inspiron 15-7547 Keyboard Replacement: step 10, image 2 of 2
      • Remove the Wifi-Card from its socket by pulling away and up from the connector.
      Ask FixBot
    3. Dell Inspiron 15-7547 Keyboard Replacement: step 11, image 1 of 2 Dell Inspiron 15-7547 Keyboard Replacement: step 11, image 2 of 2
      • Disconnect the white and black cables from the Wifi-Card.
      • Make a note of which wire goes where for reconnecting them to the replacement card.
      Ask FixBot
    1. Dell Inspiron 15-7547 Keyboard Replacement, Speakers: step 12, image 1 of 3 Dell Inspiron 15-7547 Keyboard Replacement, Speakers: step 12, image 2 of 3 Dell Inspiron 15-7547 Keyboard Replacement, Speakers: step 12, image 3 of 3
      • Orient the computer so that the hinge for the display facing away from you.
      • Start removing the speaker on the left by pushing the speaker in the direction of the tick mark on the 2 outer pegs, then upwards
      • The tick marks on the two marked pegs should indicate the speaker needs to be pushed towards the center of the front of the chassis.
      Ask FixBot
    2. Dell Inspiron 15-7547 Keyboard Replacement: step 13, image 1 of 2 Dell Inspiron 15-7547 Keyboard Replacement: step 13, image 2 of 2
      • Remove the left speaker by pushing the speaker in the direction of the tick mark on the center peg, then upwards
      • The tick mark should indicate towards the middle of the back of the chassis.
      Ask FixBot
    3. Dell Inspiron 15-7547 Keyboard Replacement: step 14, image 1 of 2 Dell Inspiron 15-7547 Keyboard Replacement: step 14, image 2 of 2
      • Remove the wire connecting the left speaker to the right speaker.
      • The wire is secured by small notches, be careful not to break these.
      Ask FixBot
    4. Dell Inspiron 15-7547 Keyboard Replacement: step 15, image 1 of 2 Dell Inspiron 15-7547 Keyboard Replacement: step 15, image 2 of 2
      • Start removing the right speaker by pushing the speaker in the direction of the tick marks on the 2 pegs closest to the front of the device, and then upwards.
      • These tick marks should indicate towards the middle of the back of the chassis.
      Ask FixBot
    5. Dell Inspiron 15-7547 Keyboard Replacement: step 16, image 1 of 1
      • Remove the right speaker by pushing in the direction of the tick mark on the final peg, and then upwards.
      • This tick mark should point towards the center of the right side of the chassis.
      Ask FixBot
    6. Dell Inspiron 15-7547 Keyboard Replacement: step 17, image 1 of 2 Dell Inspiron 15-7547 Keyboard Replacement: step 17, image 2 of 2
      • Remove the cable connecting the right speaker to the motherboard by pulling towards the front of the device.
      Ask FixBot
    1. Dell Inspiron 15-7547 Keyboard Replacement, CPU Fan: step 18, image 1 of 2 Dell Inspiron 15-7547 Keyboard Replacement, CPU Fan: step 18, image 2 of 2
      • Remove the two 5.0 mm-long Philips #0 screws from the fan.
      • The screw marked in orange will remain captive to the fan.
      Ask FixBot
    2. Dell Inspiron 15-7547 Keyboard Replacement: step 19, image 1 of 2 Dell Inspiron 15-7547 Keyboard Replacement: step 19, image 2 of 2
      • Disconnect the wire that connects the fan to the motherboard. This can be found under the flap directly to the left of the fan.
      Ask FixBot
    3. Dell Inspiron 15-7547 Keyboard Replacement: step 20, image 1 of 1
      • Lift the fan out of the chassis.
      Ask FixBot
    1. Dell Inspiron 15-7547 Keyboard Replacement, LCD Assembly: step 21, image 1 of 3 Dell Inspiron 15-7547 Keyboard Replacement, LCD Assembly: step 21, image 2 of 3 Dell Inspiron 15-7547 Keyboard Replacement, LCD Assembly: step 21, image 3 of 3
      • Remove the six 7.0 mm-long Philips #0 screws that mount the hinges.
      Ask FixBot
    2. Dell Inspiron 15-7547 Keyboard Replacement: step 22, image 1 of 3 Dell Inspiron 15-7547 Keyboard Replacement: step 22, image 2 of 3 Dell Inspiron 15-7547 Keyboard Replacement: step 22, image 3 of 3
      • Use a spudger to unlatch and unplug the display cable.
      • There will be a notch on the side of the connector.
      Ask FixBot
    3. Dell Inspiron 15-7547 Keyboard Replacement: step 23, image 1 of 3 Dell Inspiron 15-7547 Keyboard Replacement: step 23, image 2 of 3 Dell Inspiron 15-7547 Keyboard Replacement: step 23, image 3 of 3
      • Raise the left and right hinges.
      Ask FixBot
    4. Dell Inspiron 15-7547 Keyboard Replacement: step 24, image 1 of 1
      • Remove the LCD display assembly from the laptop.
      Ask FixBot
    1. Dell Inspiron 15-7547 Keyboard Replacement, Motherboard: step 25, image 1 of 3 Dell Inspiron 15-7547 Keyboard Replacement, Motherboard: step 25, image 2 of 3 Dell Inspiron 15-7547 Keyboard Replacement, Motherboard: step 25, image 3 of 3
      • Unlatch the ribbon cable by pulling the white release up.
      • If this proves to be difficult using your fingers, try a plastic spudger.
      • Hold the blue flap and pull to unplug the cable.
      Ask FixBot
    2. Dell Inspiron 15-7547 Keyboard Replacement: step 26, image 1 of 3 Dell Inspiron 15-7547 Keyboard Replacement: step 26, image 2 of 3 Dell Inspiron 15-7547 Keyboard Replacement: step 26, image 3 of 3
      • Unlatch black release on the ribbon cable.
      • Hold the blue flap to unplug the cable.
      Ask FixBot
    3. Dell Inspiron 15-7547 Keyboard Replacement: step 27, image 1 of 3 Dell Inspiron 15-7547 Keyboard Replacement: step 27, image 2 of 3 Dell Inspiron 15-7547 Keyboard Replacement: step 27, image 3 of 3
      • Unlatch the ribbon cable by pulling the black release up.
      • Unlike the others, this release is found at the back.
      • Hold the flap and unplug the cable.
      Ask FixBot
    4. Dell Inspiron 15-7547 Keyboard Replacement: step 28, image 1 of 3 Dell Inspiron 15-7547 Keyboard Replacement: step 28, image 2 of 3 Dell Inspiron 15-7547 Keyboard Replacement: step 28, image 3 of 3
      • Unlike the others this release is found at back.
      • Hold the blue flap and unplug the cable.
      Ask FixBot
    5. Dell Inspiron 15-7547 Keyboard Replacement: step 29, image 1 of 3 Dell Inspiron 15-7547 Keyboard Replacement: step 29, image 2 of 3 Dell Inspiron 15-7547 Keyboard Replacement: step 29, image 3 of 3
      • Unplug the DC jack cable.
      Ask FixBot
    6. Dell Inspiron 15-7547 Keyboard Replacement: step 30, image 1 of 2 Dell Inspiron 15-7547 Keyboard Replacement: step 30, image 2 of 2
      • Remove the seven 3.0 mm-long Philips #0 screws that secure the motherboard.
      Ask FixBot
    7. Dell Inspiron 15-7547 Keyboard Replacement: step 31, image 1 of 1
      • Remove the motherboard from the laptop.
      Ask FixBot
    1. Dell Inspiron 15-7547 Keyboard Replacement, Keyboard: step 32, image 1 of 2 Dell Inspiron 15-7547 Keyboard Replacement, Keyboard: step 32, image 2 of 2
      • Remove the five 2.0 mm-long Philips #00 screws from the metal back-plate.
      Ask FixBot
    2. Dell Inspiron 15-7547 Keyboard Replacement: step 33, image 1 of 3 Dell Inspiron 15-7547 Keyboard Replacement: step 33, image 2 of 3 Dell Inspiron 15-7547 Keyboard Replacement: step 33, image 3 of 3
      • Peal away the two plastic covers marked GPU fan and CPU fan.
      • If never previously removed, these covers should be removed very gently so as to not tear the plastic underneath.
      Ask FixBot
    3. Dell Inspiron 15-7547 Keyboard Replacement: step 34, image 1 of 2 Dell Inspiron 15-7547 Keyboard Replacement: step 34, image 2 of 2
      • Remove the twenty-two 2.0 mm-long Philips #00 screws that connect the keyboard to the chassis.
      Ask FixBot
    4. Dell Inspiron 15-7547 Keyboard Replacement: step 35, image 1 of 1
      • Lift the the keyboard from the chassis.
      Ask FixBot
1 Guide Comment
I'm trying to source the 22 , 2.0 mm-long screws that connect the keyboard to the chassis but I dont know what the correct specifications to look for, can someone please help?
Marlon Fraser - Reply Share
Past 24 Hours: 2
Past 7 Days: 20
Past 30 Days: 79
All Time: 3,257
