Dell Inspiron 15-7547 RAM Replacement
    1. Dell Inspiron 15-7547 RAM Replacement, Bottom Cover: step 1, image 1 of 1
      • Before you begin, be sure to turn off your laptop and unplug it from the outlet.
      • Close the display and flip the laptop on its back.
      • Loosen the ten 5.0 mm-long Phillips #0 screws.
      • The four screws marked with orange will remain captive to the cover.
      Ask FixBot
    2. Dell Inspiron 15-7547 RAM Replacement: step 2, image 1 of 1
      • Use a spudger to pry up and loosen the back cover.
      • Remove the back cover.
      Ask FixBot
    1. Dell Inspiron 15-7547 RAM Replacement, RAM: step 3, image 1 of 3 Dell Inspiron 15-7547 RAM Replacement, RAM: step 3, image 2 of 3 Dell Inspiron 15-7547 RAM Replacement, RAM: step 3, image 3 of 3
      • Remove the plastic heat spreader that covers the RAM sticks.
      Ask FixBot
    2. Dell Inspiron 15-7547 RAM Replacement: step 4, image 1 of 2 Dell Inspiron 15-7547 RAM Replacement: step 4, image 2 of 2
      • Release the clamps on each side of the RAM sticks by pushing away from the center.
      • When done properly the RAM stick should pop up.
      Ask FixBot
    3. Dell Inspiron 15-7547 RAM Replacement: step 5, image 1 of 2 Dell Inspiron 15-7547 RAM Replacement: step 5, image 2 of 2
      • Pull the RAM stick in a straight line out of the socket.
      Ask FixBot
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 17
Past 30 Days: 63
All Time: 736
