Scanner is not functioning properly
The scanner does not capture the correct image.
Scanner glass is broken
If the scanner's glass is cracked, chipped or shattered, it can be easily replaced here.
Scanner belt is not working
If your scanner won't run, you may need to replace the belt. You can find a guide for that here.
Scanner light doesn't turn on
If the scanner's light doesn't turn on, it may be broken and need replacement. You can find this guide here.
Printer makes a buzzing sound
The printer makes a buzzing sound when it is on.
Bad transformer
If your printer is making a buzzing noise, you may need to replace the transformer. Check out our guide here.
Audio malfunction
The printer is providing distorted sound or no sound at all.
Broken speaker
If your printer's audio is misbehaving, you may need to replace the speaker. Check out our guide here.
Printer is unresponsive
The printer does not seem to have power and pressing the buttons does not do anything.
Ensure that the printer is plugged into a wall outlet.
This can be easily solved by plugging in the power cord to the wall and ensuring that the power cord is also plugged into the printer.
Printer is not turned on
To turn the printer on press and hold the power button on the front of the printer. You should only have to press the power button for a couple of seconds and it should turn on.
Ink on the paper is faded.
The printer does not print the ink as it should.
Missing ink cartridge
This can be solved by opening up the printer and finding where the printer ink cartridge goes.
Low ink cartridge
Like the one above, this can be solved by finding the printer ink cartridge goes and replacing the old cartridge with the new cartridge.
Helena Yanez
470 Reputation
4 Guides authored
Cal Poly, Team 13-1, Forte Fall 2013 Member of Cal Poly, Team 13-1, Forte Fall 2013
CPSU-FORTE-F13S13G1
5 Members
96 Guides authored
12 Comments
the Canon mf4350d is still printing but when it does print it makes a very loud Grinding noise.
HELP
Norb Mechley - Reply Share
Chek document
Mohammad Mamun - Reply Share
Check document
la impresora canon me arroja un Error E000 en la canon 4350mf
pablo - Reply Share
My printer is not connecting with my computer.
cjoyhunt - Reply Share
Past 24 Hours: 1
Past 7 Days: 5
Past 30 Days: 49
All Time: 6,969
