Canon ImageCLASS MF4350d Scanner Belt Replacement
Views: 3.9K
View statistics:
Past 24 Hours:
4
Past 7 Days:
21
Past 30 Days:
108
All Time:
3,901
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 15 - 30 minutes
Difficulty: Easy
Introduction
Go to step 1 ↓
If you find that your scanner light does not seem to be moving, then your scanner belt could be the problem. Your scanner belt could be damaged or worn. This guide will help you to replace your scanner belt.
Tools
    1. Canon ImageCLASS MF4350d Scanner Belt Replacement, Scanner Disassembly: step 1, image 1 of 1
      • If at any point you see glass that seems cracked or broken, handle with care. Broken glass is sharp and can cause serious damage.
      • Lift up the lid. Then be sure to examine the glass. If there are any cracks or broken fragments handle with extreme care.
      Ask FixBot
    2. Canon ImageCLASS MF4350d Scanner Belt Replacement: step 2, image 1 of 3 Canon ImageCLASS MF4350d Scanner Belt Replacement: step 2, image 2 of 3 Canon ImageCLASS MF4350d Scanner Belt Replacement: step 2, image 3 of 3
      • Locate the black and white hinges.
      • Gently lift out the black and white hinges.
      Ask FixBot
    3. Canon ImageCLASS MF4350d Scanner Belt Replacement: step 3, image 1 of 3 Canon ImageCLASS MF4350d Scanner Belt Replacement: step 3, image 2 of 3 Canon ImageCLASS MF4350d Scanner Belt Replacement: step 3, image 3 of 3
      • Next, locate and remove the four 10mm screws.
      Ask FixBot
    4. Canon ImageCLASS MF4350d Scanner Belt Replacement: step 4, image 1 of 1
      • Gently, pry off the top plate, starting from the back of the printer.
      Ask FixBot
    5. Canon ImageCLASS MF4350d Scanner Belt Replacement: step 5, image 1 of 2 Canon ImageCLASS MF4350d Scanner Belt Replacement: step 5, image 2 of 2
      • After you have taken off the plate, check to make sure that there is no broken glass. If there is broken glass handle it with gloves. Broken glass, if handled improperly, can cause physical injury.
      Ask FixBot
    1. Canon ImageCLASS MF4350d Scanner Belt Replacement, Scanner Belt: step 6, image 1 of 2 Canon ImageCLASS MF4350d Scanner Belt Replacement, Scanner Belt: step 6, image 2 of 2
      • Remove the black component by gently pulling it up from the black scanner belt
      Ask FixBot
    2. Canon ImageCLASS MF4350d Scanner Belt Replacement: step 7, image 1 of 2 Canon ImageCLASS MF4350d Scanner Belt Replacement: step 7, image 2 of 2
      • Press down on the white release and force it in toward the spring as shown. While you do this, pull the scanner belt out of the track.
      • Take a new belt and put it in the same way that you took it out.
      Ask FixBot
Tanner Papenfuss
584 Reputation
4 Guides authored
Cal Poly, Team 13-1, Forte Fall 2013 Member of Cal Poly, Team 13-1, Forte Fall 2013
CPSU-FORTE-F13S13G1
5 Members
96 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 21
Past 30 Days: 108
All Time: 3,901
