Canon ImageCLASS MF4350d Speaker Replacement
    1. Canon ImageCLASS MF4350d Speaker Replacement, Front Paneling: step 1, image 1 of 1
      • Lift the printer lid up as shown in the photo.
      Ask FixBot
    2. Canon ImageCLASS MF4350d Speaker Replacement: step 2, image 1 of 2 Canon ImageCLASS MF4350d Speaker Replacement: step 2, image 2 of 2
      • Locate and remove the two 10mm side screws. There is one on each side.
      Ask FixBot
    3. Canon ImageCLASS MF4350d Speaker Replacement: step 3, image 1 of 2 Canon ImageCLASS MF4350d Speaker Replacement: step 3, image 2 of 2
      • Unhook the plastic panel from the printer starting from the top.
      • You may need to wiggle the panel a bit to loosen it.
      • To remove the bottom part of the paneling gently lay the printer on its back.
      • The scanner lid needs to be supported when moving the printer
      Ask FixBot
    1. Canon ImageCLASS MF4350d Speaker Replacement, Right Side Paneling: step 4, image 1 of 3 Canon ImageCLASS MF4350d Speaker Replacement, Right Side Paneling: step 4, image 2 of 3 Canon ImageCLASS MF4350d Speaker Replacement, Right Side Paneling: step 4, image 3 of 3
      • Gently unhook the right side paneling (as looking at the printer's front face) from the printer.
      • Use a gentle back and forth motion to wiggle the hooks out.
      Ask FixBot
    1. Canon ImageCLASS MF4350d Speaker Replacement, Speaker: step 5, image 1 of 1
      • Lay printer on its left side for better access to the speaker.
      Ask FixBot
    2. Canon ImageCLASS MF4350d Speaker Replacement: step 6, image 1 of 2 Canon ImageCLASS MF4350d Speaker Replacement: step 6, image 2 of 2
      • Using a Phillips head screw driver, unscrew the 7mm screw.
      Ask FixBot
    3. Canon ImageCLASS MF4350d Speaker Replacement: step 7, image 1 of 3 Canon ImageCLASS MF4350d Speaker Replacement: step 7, image 2 of 3 Canon ImageCLASS MF4350d Speaker Replacement: step 7, image 3 of 3
      • Locate the red and black wires connected to the speaker.
      • Undo the white clip holding the wires in place by pinching the tab on the top.
      • Remove the red and black wires from the wire bundle.
      • When replacing the old speaker, do not touch any part of the new speaker that is not metal other than the wires. Doing so could damage the speaker.
      • Lift out the speaker
      Ask FixBot
Helena Yanez
470 Reputation
4 Guides authored
Cal Poly, Team 13-1, Forte Fall 2013 Member of Cal Poly, Team 13-1, Forte Fall 2013
CPSU-FORTE-F13S13G1
5 Members
96 Guides authored
0 Guide Comments
Past 24 Hours: 6
Past 7 Days: 18
Past 30 Days: 31
All Time: 1,854
