Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
Screen does not turn on
LCD screen is visibly cracked, or the screen will not power on.
Faulty Battery
Check light on top of camera to see if power is on. If the light does not come on, charge the battery. If the problem is not solved after charging the battery, consider purchasing a new battery.
Faulty Flex Connector
If the camera is functioning normally, but the screen remains black, the flex connector may have a fault. To fix this the entire screen needs to be replaced. Follow this link to replace the Flex Connector: Canon PowerShot SD1400 IS Screen Replacement
Device Unresponsive
The lense cover is closed, the screen is black, the control panel is unresponsive, or you are unable to take pictures.
Software error
Software errors can be resolved by restarting the camera. Power off the camera, then power the camera back on.
Control Panel Unresponsive
Control panel issues will require the replacement of the user interface panel. This may be the case if the buttons next to the screen are broken, stuck, or unresponsive. Information on how to replace the user interface panel can be found on the following page:
Procedure for Replacing the Canon PowerShot SD1400 IS Control Panel
Image Capture Button Unresponsive
If the image capture button is broken or unresponsive, it will need to be replaced. If this is the case, the button will not cause any response on the screen or will be locked in place. Information for replacing the image capture button can be found on the following page:
Canon PowerShot SD1400 IS Image Capture Button Replacement
Gears out of alignment
If the issue is not fixed by restarting the camera, the gears may be out of alignment. This can only be fixed professionally, and the camera will need to be submitted to Canon for repair.
Shutter Won't Function Properly
Frequent usage will result in the camera shutter becoming stuck or dirty. The following guide shows how to clean out the camera shutter.
[invalid guide link]
Camera Will Not Power On
The power indicator light does not turn on, and no camera activity occurs when the power button is pushed.
Drained Battery.
Try charging the battery. Information for how to do this can be found at the following page:
https://support.usa.canon.com/kb/index?p...
Faulty Battery
To replace the battery, slide the battery case cover away from the camera to unlock it, then open the casing. Slide the orange tab away from the battery to release the battery. The battery will automatically eject. Ensure the battery is removed, then insert the new battery. More information for how to do this can be found at the following page:
Procedure for Replacing the Canon PowerShot SD1400 IS Battery
Device Won't Read Memory Card
User is not able to store photos onto the camera.
LCD screen display shows “No Memory Card” message.
To fix this problem, follow this guide:
Canon PowerShot SD1400 IS Memory Card Troubleshooting
Blank event window
Corrupt Images on memory card cause the event window to be blank. To fix this problem, follow this guide:
More Canon PowerShot SD1400 IS Memory Card Troubleshooting
Wes Joslin
153 Reputation
0 Guides authored
Baylor, Team S1-G3, Johnson Spring 2018 Member of Baylor, Team S1-G3, Johnson Spring 2018
BU-JOHNSON-S18S1G3
3 Members
48 Guides authored
4 Comments
What do I do if I dropped my camera and the lens are acting up? Whenever I turn it on now the screen says
“lens error
will shutdown automatically
restart camera”
and then the lens start to retract and go back, like in and out. And sometimes it makes a clicking noise like something’s stuck in there. Please help. My mother gave me this camera. Even though the company probably doesn’t make these anymore, It holds a lot of value to me. Thank you and God Bless.
Bianca Pimentel - Reply Share
My camera is doing the same thing. Were you ever able to fix it?
Beth Sullivan - Reply Share
I have the same problem. Didn’t drop it though. It just started doing that one day. Manual says dust got in the lens. Tried using air spray but no luck. Hope someone offers a solution. It is a nice camera.
ixtayul - Reply Share
My LCD screen remains black and does not display images, as far as those intended to photograph, or on the SD memory card. The settings are all displayed on the screen as usual, (Flash, power, photo/video, etc). All menus are displayed normally and can be adjusted. I have replaced the battery, and changed the SD card, no change. Suggestions? Solutions?
Richard - Reply Share
Past 24 Hours: 1
Past 7 Days: 14
Past 30 Days: 55
All Time: 2,505
