Canon PowerShot SD1400 IS User Interface Panel Replacement
View statistics:
Past 24 Hours:
2
Past 7 Days:
17
Past 30 Days:
61
All Time:
767
Comments: 0
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 10 - 15 minutes
Difficulty: Easy
Introduction
Go to step 1 ↓
The buttons on the user interface panel can become broken or stuck. This guide will show how to replace the user interface panel on the Canon PowerShot SD1400 IS.
Parts
Tools
    1. Canon PowerShot SD1400 IS User Interface Panel Replacement, User Interface Panel: step 1, image 1 of 3 Canon PowerShot SD1400 IS User Interface Panel Replacement, User Interface Panel: step 1, image 2 of 3 Canon PowerShot SD1400 IS User Interface Panel Replacement, User Interface Panel: step 1, image 3 of 3
      • Remove the four 2.0 mm Phillips screws of the camera using the J00 bit from the 54-bit Driver Kit. There are two screws on both sides.
      Ask FixBot
    2. Canon PowerShot SD1400 IS User Interface Panel Replacement: step 2, image 1 of 1
      • Remove the 4.0 mm Phillips screw located on the bottom of the camera.
      Ask FixBot
    3. Canon PowerShot SD1400 IS User Interface Panel Replacement: step 3, image 1 of 1
      • Remove the front face panel of the camera by hand using firm pressure.
      • If one point of the face is stuck to the body, check if there is a screw preventing the front face from coming off.
      Ask FixBot
    4. Canon PowerShot SD1400 IS User Interface Panel Replacement: step 4, image 1 of 1
      • Remove the rear panel of the camera by hand using firm pressure.
      Ask FixBot
    5. Canon PowerShot SD1400 IS User Interface Panel Replacement: step 5, image 1 of 1
      • Remove the user interface panel by hand. The panel may fall out on its own, this is normal.
      • Replace the user interface panel by setting it in position.
      Ask FixBot
2 other people completed this guide.
Braxton Beal
702 Reputation
3 Guides authored
Baylor, Team S1-G3, Johnson Spring 2018 Member of Baylor, Team S1-G3, Johnson Spring 2018
BU-JOHNSON-S18S1G3
3 Members
48 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 17
Past 30 Days: 61
All Time: 767
