Canon PowerShot SD1400 IS Image Capture Button Replacement
View statistics:
Past 24 Hours:
Past 7 Days:
12
Past 30 Days:
59
All Time:
865
Comments: 1
1 guide comment.
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 30 - 35 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
The image capture button can break or become stuck. This guide details how to replace the image capture button and the surrounding plastic housing on the Canon PowerShot SD1400 IS camera.
Tools
    1. Canon PowerShot SD1400 IS Image Capture Button Replacement, Image Capture Button: step 1, image 1 of 2 Canon PowerShot SD1400 IS Image Capture Button Replacement, Image Capture Button: step 1, image 2 of 2
      • Use a Phillips #00 driver to remove the four 2.0 mm Phillips screws on the camera housing.
      • There are two screws on either side.
      Ask FixBot
    2. Canon PowerShot SD1400 IS Image Capture Button Replacement: step 2, image 1 of 1
      • Use a Phillips #1 driver to remove the one 4.0 mm Phillips screw located on the bottom of the camera.
      Ask FixBot
    3. Canon PowerShot SD1400 IS Image Capture Button Replacement: step 3, image 1 of 1
      • Remove the face housing from the body of the camera.
      Ask FixBot
    4. Canon PowerShot SD1400 IS Image Capture Button Replacement: step 4, image 1 of 1
      • Turn the camera over and remove the rear housing.
      Ask FixBot
    5. Canon PowerShot SD1400 IS Image Capture Button Replacement: step 5, image 1 of 1
      • Remove the button panel if it did not fall out on its own.
      Ask FixBot
    6. Canon PowerShot SD1400 IS Image Capture Button Replacement: step 6, image 1 of 1
      • Use a Phillips #0 driver to remove the one 3.0 mm Phillips copper screw from the top of the camera.
      • This screw is only visible after the front and rear panels have been removed.
      Ask FixBot
    7. Canon PowerShot SD1400 IS Image Capture Button Replacement: step 7, image 1 of 1
      • Use a Phillips #0 driver to remove the one 3.0 mm Phillips silver screw from the rear face of the camera.
      Ask FixBot
    8. Canon PowerShot SD1400 IS Image Capture Button Replacement: step 8, image 1 of 1
      • Use a plastic spudger to lift the golden film off of the microchip on the front face of the camera, exposing a screw.
      Ask FixBot
    9. Canon PowerShot SD1400 IS Image Capture Button Replacement: step 9, image 1 of 1
      • Use a Phillips #0 driver to remove the one 3.0 mm Phillips screw.
      Ask FixBot
    10. Canon PowerShot SD1400 IS Image Capture Button Replacement: step 10, image 1 of 2 Canon PowerShot SD1400 IS Image Capture Button Replacement: step 10, image 2 of 2
      • Use a metal spudger to carefully pry the small black tab away from the connector that secures one end of the golden film.
      • When fully released, the small black tab will stand up straight from the face of the camera and the golden film will no longer be secured.
      Ask FixBot
    11. Canon PowerShot SD1400 IS Image Capture Button Replacement: step 11, image 1 of 1
      • Carefully insert a metal spudger under the two clusters of wires that are plugged into the small chip on the face of the camera.
      • One cluster of wires is red, the other cluster is black.
      • Pull the wires parallel to the face of the camera to disconnect them from the small chip.
      Ask FixBot
    12. Canon PowerShot SD1400 IS Image Capture Button Replacement: step 12, image 1 of 1
      • The image capture button housing can now be removed from the body of the camera and replaced.
      Ask FixBot
Follow these instructions in reverse order to reassemble the device.
Braxton Beal
702 Reputation
3 Guides authored
Baylor, Team S1-G3, Johnson Spring 2018 Member of Baylor, Team S1-G3, Johnson Spring 2018
BU-JOHNSON-S18S1G3
3 Members
48 Guides authored
1 Guide Comment
Where can do you buy replacement parts?
Chase Mahard - Reply Share
Past 24 Hours: 1
Past 7 Days: 12
Past 30 Days: 59
All Time: 865
