Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
Keyboard Doesn't Work at All
No matter what you do, you can't get your keyboard to turn on.
Computer Doesn’t Recognize the Keyboard Is Connected
Try unplugging the USB cable and plugging it back in. If that doesn’t work, try using a different USB cable to connect the keyboard to the computer. If that solution fails, the keyboard’s PCB might be dysfunctional.
Wrong Driver
If your computer fails to properly install a driver for the keyboard, go here and download the correct driver for your keyboard and operating system.
Bad Connections Inside Computer
It’s possible that the USB port in your computer has lost connection with the computer’s motherboard; if so, you’ll need to open up your computer and re-attach the internal USB cable with the motherboard. Search iFixit for instructions on how to do this with your computer.
Just a Few Keys Aren’t Working
Most of the keys work, but a few don't.
Dust
If the keyboard has been used for a long time, there might be some crumbs from daily use. A vacuum cleaner can be used to remove small debris from the keyboard.
Replacing Keycaps
Some keys are shiny with use, and replacing them is much cheaper than buying a new keyboard.
Installing new keycaps
If the keyboard’s key caps are dirty or shiny from overuse, you can replace them by following this guide for small keys, and this guide for larger ones.
Keyboard is Too Loud
Your fancy mechanical keyboard is too loud!
Loud Clicking Noise while Typing
If you feel that the keyboard is too loud, you can purchase and install O-rings to reduce noise. Follow this guide for installation on smaller keys and this guide for installation on larger ones.
Lights don’t work
The LEDs on your keyboard don't light up.
Replace LED Lights
If a light on the keyboard is dysfunctional, you can replace it by following this guide.
Author
with
Shiva Empranthiri
781 Reputation
4 Guides authored
Cal Poly, Team 6-23, Maness Fall 2014 Member of Cal Poly, Team 6-23, Maness Fall 2014
CPSU-MANESS-F14S6G23
4 Members
72 Guides authored
3 Comments
My cable broke. What now?
Rúben Gomes (CodeName1337) - Reply Share
It’s a standard USB cable. I had to trim away the strain relief boot on a spare cable I wanted to use.
Charles Gunzelman - Reply Share
My keyboard is registering connection (lighting up caps lock and print screen) but none of the keys are working (can't turn off caps lock or print screen light). i've had the keyboard for a while now and had this problem once previously and solved it with a random code on keys to unlock it on a forum i can no longer find. any tips would be helpful!!
Haley Boswell - Reply Share
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 46
All Time: 14,215
