Up to 20% off select tools
CM Storm QuickFire Rapid Small Keycap Replacement
Views: 3K
View statistics:
Past 24 Hours:
4
Past 7 Days:
23
Past 30 Days:
102
All Time:
3,050
Comments: 0
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 1 - 2 minutes
Difficulty: Easy
Introduction
Go to step 1 ↓
Replacing keycaps is one of the most common operations performed on a keyboard. Follow this guide to learn how to replace small keycaps on your mechanical keyboard.
    1. CM Storm QuickFire Rapid Small Keycap Replacement, Small Keycap: step 1, image 1 of 1
      • Insert the keycap puller around the key you want to remove.
      Ask FixBot
    2. CM Storm QuickFire Rapid Small Keycap Replacement: step 2, image 1 of 1
      • Pull cap directly upward.
      Ask FixBot
2 other people completed this guide.
Author
with
Shiva Empranthiri
781 Reputation
4 Guides authored
Cal Poly, Team 6-23, Maness Fall 2014 Member of Cal Poly, Team 6-23, Maness Fall 2014
CPSU-MANESS-F14S6G23
4 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 23
Past 30 Days: 102
All Time: 3,050
