Up to 20% off select tools
CM Storm QuickFire Rapid Large Keycap Replacement
Views: 6.6K
View statistics:
Past 24 Hours:
5
Past 7 Days:
21
Past 30 Days:
100
All Time:
6,617
Comments: 0
Go to guide comments
Completed: 0
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: No estimate
Difficulty: Moderate
Missing Prerequisites
This guide is missing information on how to start the process. Make a prerequisite guide!
Introduction
Go to step 1 ↓
Replacing keycaps is one of the most common operations performed on a keyboard. Follow this guide to learn how to replace large keycaps on your mechanical keyboard.
    1. CM Storm QuickFire Rapid Large Keycap Replacement, Remove surrounding keycaps: step 1, image 1 of 3 CM Storm QuickFire Rapid Large Keycap Replacement, Remove surrounding keycaps: step 1, image 2 of 3 CM Storm QuickFire Rapid Large Keycap Replacement, Remove surrounding keycaps: step 1, image 3 of 3
      Ask FixBot
    2. CM Storm QuickFire Rapid Large Keycap Replacement: step 2, image 1 of 1
      • Pull the large keycap upward with your fingers until the cap separates from the plastic rings underneath the cap. If the metal bar beneath the cap comes loose during removal, snap it back in place.
      Ask FixBot
    3. CM Storm QuickFire Rapid Large Keycap Replacement: step 3, image 1 of 3 CM Storm QuickFire Rapid Large Keycap Replacement: step 3, image 2 of 3 CM Storm QuickFire Rapid Large Keycap Replacement: step 3, image 3 of 3
      • Install the plastic rings on the new keycap. The overhang needs to be ‘facing forward’ so that when the keycap is placed back on the board, the overhang is furthest away from you. When attaching the new key to the board, the ends of the metal bar on the board will go through these rings.
      Ask FixBot
Author
with
Shiva Empranthiri
781 Reputation
4 Guides authored
Cal Poly, Team 6-23, Maness Fall 2014 Member of Cal Poly, Team 6-23, Maness Fall 2014
CPSU-MANESS-F14S6G23
4 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 21
Past 30 Days: 100
All Time: 6,617
