CM Storm QuickFire Rapid O-ring: Large Keycap Installation
    1. CM Storm QuickFire Rapid O-ring: Large Keycap Installation, O-ring: Large Keycap: step 1, image 1 of 3 CM Storm QuickFire Rapid O-ring: Large Keycap Installation, O-ring: Large Keycap: step 1, image 2 of 3 CM Storm QuickFire Rapid O-ring: Large Keycap Installation, O-ring: Large Keycap: step 1, image 3 of 3
      Ask FixBot
    2. CM Storm QuickFire Rapid O-ring: Large Keycap Installation: step 2, image 1 of 1
      • Pull the large keycap upward with your fingers until the cap separates from the plastic rings underneath the cap. If the metal bar beneath the cap comes loose during removal, snap it back in place.
      Ask FixBot
    3. CM Storm QuickFire Rapid O-ring: Large Keycap Installation: step 3, image 1 of 3 CM Storm QuickFire Rapid O-ring: Large Keycap Installation: step 3, image 2 of 3 CM Storm QuickFire Rapid O-ring: Large Keycap Installation: step 3, image 3 of 3
      • Remove the plastic rings from the keycap.
      Ask FixBot
    4. CM Storm QuickFire Rapid O-ring: Large Keycap Installation: step 4, image 1 of 2 CM Storm QuickFire Rapid O-ring: Large Keycap Installation: step 4, image 2 of 2
      • Place the O-rings around the nubs underneath the keycap at each circled locations.
      Ask FixBot
Shiva Empranthiri
781 Reputation
4 Guides authored
Cal Poly, Team 6-23, Maness Fall 2014 Member of Cal Poly, Team 6-23, Maness Fall 2014
CPSU-MANESS-F14S6G23
4 Members
72 Guides authored
1 Guide Comment
Best choice if you want all the “click” but none of the “clack” on your mechanical keyboard
Cherry Mx Black Rubber O-rings (125 pcs -EPDM – 40A) €3,98
Cherry Mx Black Rubber O-rings (90 pcs -EPDM – 40A) €3,48
[NL] O-rings Webstore http://tigri.bigcartel.com
Specs
Material: EPDM Industrial Grade Rubber
Color: Black
Hardness: 40A
Thickness: 1,50 mm (0.059 in)
Packaging: 125 pcs/bag or 90 pcs/bag
tigriorings - Reply Share
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 28
All Time: 2,388
