Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
Saw won't turn on
The saw will not power up or show signs of life
The cord is not plugged in
Make sure the cord is plugged into a working outlet. If the cord is cut or damaged then you can simply fix it by following our free guide here.
Tripped Breaker
Each circuit has a breaker that lowers the risk of electric shock. From time to time the breakers will trigger and shut off a circuit. To reset the circuit, you have to find the breaker box and identify the breaker that popped. Normally you just need to find the one in the OFF position and switch it to the ON position.
Broken trigger
If the saw is not responding at all, then the trigger could be broken. In that case you will have to take off the housing of the motor and use a multi-meter to check if the component is broken or not. A guide to testing and replacing your trigger can be found here.
Blown out motor
The only way to see if the motor is blown out or broken is to use a multi-meter and check the electrical connection through it. You can follow our guide to replace it here.
Blade is loose or falling out
The blade falls out of the saw and/or is loose causing cuts to not be straight
Broken Blade
Check the blade itself to see if the tang (part that goes into the saw) is chipped, cracked, or broken off. If this is the case, the blade must be replaced.
Broken Blade Mount
Check to see that the blade mount is not missing any hardware that would keep it functioning properly. If so, replace the hardware. If that is not the problem, the blade mount most likely needs replacing. A guide to replacement can be found here
Smart Select Dial does not Change Speeds
When changing the Smart Select dial to cut different materials, the blade speed does not change.
Broken Smart Select Dial
First, check to make sure that the Smart Select dial feels firm and like it is engaged. If it isn't, make sure it is firmly in place. If it is firmly in place, the entire Smart Select dial probably needs replacing.
Shoe Plate is Loose or Vibrates
The metal plate sitting on the bottom of the device is loose or has fallen off.
Shoe Plate is Unlocked
Check to see if the shoe plate bevel lever is pushed away from the saw.
Shoe Plate is Broken
If the shoe plate bevel lever is pushed away from the saw and the shoe plate still is loose, the shoe plate needs to be replaced. the guide can be found here
Saw Makes Odd Noises
"The Saw vibrates too much or makes weird noises"
Gearbox Needs Grease
The most common fix to a noisy device is that it needs grease on the gearbox. A guide to getting to the gearbox can be found here
Gearbox Needs to be Realigned
Sometimes the gearbox can come loose or can be knocked out of alignment. This is the normal cause for a vibrating device. A guide to taking out the gearbox can be found here
Gearbox is Broken
If the motor is engaged but the saw will not work. Then the gearbox may be the problem. a guide to replacing it can be found here
Mohammed Makki
55 Reputation
0 Guides authored
USF Tampa, Team 6-2, Eyestone Spring 2016 Member of USF Tampa, Team 6-2, Eyestone Spring 2016
USFT-EYESTONE-S16S6G2
4 Members
48 Guides authored
5 Comments
blade will not release and come out
Gordon Kearns - Reply Share
My blade post to hold the blade is in the wrong position to put on the blade
Jeanne Courtney - Reply Share
Can't cut straight, the blade after a straight cut of only 5 inches she work to go direction 2:00 o'clock and the table go to 10:00 o'clock, I tried all the gadget setting and these options changed nothing, since I bought that I really miss my old 2 speed jigsaw, I should'nt have bought this model JS660, will have to buy an another jigsaw and put this to the garbage..can't sell a jigsaw like that to an another person.
Yves J. Fournaise - Reply Share
when I am turning on only beep is coming
How to fix it
Roheena Adeeb - Reply Share
Bevel lever is stuck in locked position
judy obrien - Reply Share
Past 24 Hours: 1
Past 7 Days: 6
Past 30 Days: 49
All Time: 17,855
