Black and Decker JS660 Trigger Replacement
    1. Black and Decker JS660 Trigger Replacement, Housing Disassembly: step 1, image 1 of 2 Black and Decker JS660 Trigger Replacement, Housing Disassembly: step 1, image 2 of 2
      • Remove the nine torx 15.875mm screws on the front of the jigsaw using a T-15 torx screwdriver.
      Ask FixBot
    2. Black and Decker JS660 Trigger Replacement: step 2, image 1 of 1
      • By separating the two housing halves, carefully remove the top plate.
      Ask FixBot
    1. Black and Decker JS660 Trigger Replacement, Power Cord: step 3, image 1 of 1
      • Remove the two 12.7mm phillips head screws holding the power cord in place with a PH2 Phillips head screwdriver.
      Ask FixBot
    2. Black and Decker JS660 Trigger Replacement: step 4, image 1 of 1
      • Remove the two 6.35mm flat head screws on the trigger with a 2.5 flat head screwdriver to disconnect the white and black cords.
      Ask FixBot
    3. Black and Decker JS660 Trigger Replacement: step 5, image 1 of 1
      • Gently remove the black and white cord from the trigger assembly.
      Ask FixBot
    1. Black and Decker JS660 Trigger Replacement, Trigger: step 6, image 1 of 1
      Tool used on this step:
      Buy
      • Use tweezers to press down on these tabs on the trigger assembly.
      • While the tab is depressed, the cord can be pulled out of the housing by using a moderate amount of force.
      • Each cord needs to be done separately.
      Ask FixBot
    2. Black and Decker JS660 Trigger Replacement: step 7, image 1 of 1
      • Remove pink wires from trigger assembly.
      Ask FixBot
matt murray
682 Reputation
6 Guides authored
Cal Poly, Team 22-9, Maness Winter 2017 Member of Cal Poly, Team 22-9, Maness Winter 2017
CPSU-MANESS-W17S22G9
4 Members
84 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 9
Past 30 Days: 33
All Time: 1,821
