Black and Decker JS660 Gear Box Replacement
  1. Black and Decker JS660 Gear Box Replacement, Housing Disassembly: step 1, image 1 of 2 Black and Decker JS660 Gear Box Replacement, Housing Disassembly: step 1, image 2 of 2
    • Remove the nine torx 15.875mm screws on the front of the jigsaw using a T-15 torx screwdriver.
    Ask FixBot
  2. Black and Decker JS660 Gear Box Replacement: step 2, image 1 of 1
    • By separating the two housing halves, carefully remove the top plate.
    Ask FixBot
  3. Black and Decker JS660 Gear Box Replacement, Blade Holder: step 3, image 1 of 1
    • Being careful to keep all parts together, grab the entire assembly and pull it directly out of the saw.
    Ask FixBot
  4. Black and Decker JS660 Gear Box Replacement, Motor: step 4, image 1 of 1
    • Remove the two 30.1625mm screws with a T20 torx screwdriver that are holding the gearbox to the housing.
    Ask FixBot
  5. Black and Decker JS660 Gear Box Replacement: step 5, image 1 of 1
    • Apply a light force to separate the gearbox from the housing. This will momentarily separate the gearbox and help with the removal of the system in later steps.
    Ask FixBot
  6. Black and Decker JS660 Gear Box Replacement: step 6, image 1 of 2 Black and Decker JS660 Gear Box Replacement: step 6, image 2 of 2
    Tool used on this step:
    Buy
    • Using tweezers or a small flathead screwdriver, gently remove each of the black magnetic clasps away from the motor.
    Ask FixBot
  7. Black and Decker JS660 Gear Box Replacement: step 7, image 1 of 1
    • Holding the gearbox and the bering, pull the whole motor and gearbox out of the housing.
    Ask FixBot
  8. Black and Decker JS660 Gear Box Replacement: step 8, image 1 of 1
    • While holding the motor in one hand, gently pull the gearbox off of the drive shaft.
    Ask FixBot
matt murray
682 Reputation
6 Guides authored
Cal Poly, Team 22-9, Maness Winter 2017 Member of Cal Poly, Team 22-9, Maness Winter 2017
CPSU-MANESS-W17S22G9
4 Members
7 Guides authored
1 Guide Comment
Hi. Can you please describe how to replace motor for BELTSANDER. Thanks. Chris
Chris Breedt - Reply Share
Past 24 Hours: 3
Past 7 Days: 7
Past 30 Days: 37
All Time: 2,022
