Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
Short Battery Life
The BlackBerry Bold 9900 will not hold a charge.
Faulty Battery
Make sure the charger is plugged into both the wall outlet and the BlackBerry Bold 9900 charging port. If the BlackBerry Bold 9900 only powers up when plugged in to the charger, regardless of charging time, then the battery is faulty. Replace the BlackBerry Bold 9900 battery with this guide.
Faulty Charging Port
Ensure that your charger is working properly. Make sure the charger is plugged into both the wall outlet and the BlackBerry Bold 9900 charging port. If the BlackBerry Bold 9900 does not power up or begin charging, then the charging port is faulty.
Cannot Make Calls
The BlackBerry Bold 9900 is not able to make or receive calls.
Faulty SIM Card
Ensure that the SIM Card is present, and if messages such as, ‘SIM card error’, or ‘SIM card not detected’ are displayed, then the SIM Card is faulty. Try replacing the SIM Card using this guide.
Faulty Memory Card
Ensure that the Memory Card is present, and if messages such as, ‘Media Card Error’, or ‘Media Card not detected’ are displayed, then the Memory Card is faulty. Replace the Memory Card with this guide.
Keyboard/Keys not Functioning Properly
The BlackBerry Bold 9900 keyboard won’t respond, or keys appear to be missing or broken.
Faulty Keyboard
If the entire keyboard fails to respond, try replacing it with this guide.
Keys Stuck in Place
Make sure all keys are responding when pressed. If some keys are sticking down when pressed, or are unable to be pressed down, try replacing the keys with this guide.
Keys Missing
Make sure no keys are missing from the keyboard. If keys are missing from the keyboard, replace the BlackBerry Bold 9900 keyboard here.
Trackpad is not able to detect finger movement
The BlackBerry Bold 9900 will not detect finger movement on the trackpad.
Faulty Trackpad
Make sure the cursor is following the movements of the finger. If the trackpad does not follow each finger movement then the trackpad is faulty. Replace the BlackBerry Bold 9900 trackpad with this guide.
Dirty Trackpad
Make sure the cursor is following the movements of the finger. If the trackpad is behaving abnormally, and has been recently exposed to any liquids or sticky substances, it is most likely too dirty to track finger movement.
Display is Pixelated, Blurry, and Distorted
The BlackBerry Bold 9900 display is distorted, blurry, or discolored.
Faulty Screen
Make sure the screen is displaying all images clearly. If the screen shows images that are distorted, blurry, or discolored, then the screen is faulty. Replace the BlackBerry Bold 9900 screen with this guide.
Impurities Beneath Screen
Make sure the screen is clean. If the screen appears slightly dirty, wet, or sticky, then it is possible that some of that muck made its way beneath the screen. Clean beneath the BlackBerry Bold 9900 screen to get rid of the grime.
Justin Ogihara
31,463 Reputation
52 Guides authored
3 Comments
اايلواجزلل
وكلطاي
Mohamad Fahed - Reply Share
if a blackberry bold 9900 is repaired from any repairing app like blackberry desktop manager, will it lose all the data after the repair?
Mac Jaypee Vente - Reply Share
I can’t open my blackberry bold 9900 but when I plugged the charger the red light keeps flashing on and off. What should I do to fix it? please help….
zoey park - Reply Share
Past 24 Hours: 2
Past 7 Days: 9
Past 30 Days: 56
All Time: 2,556
