Blackberry Bold 9900 Keyboard Replacement
  1. Blackberry Bold 9900 Keyboard Replacement, Battery: step 1, image 1 of 1
    • Place phone screen down.
    • Use your finger to life upward on the battery case.
    • Pull the cover away from the battery.
    Ask FixBot
  2. Blackberry Bold 9900 Keyboard Replacement: step 2, image 1 of 1
    • Lift the edge of battery with the green stripe upward to remove battery.
    Ask FixBot
  3. Blackberry Bold 9900 Keyboard Replacement, MicroSD card: step 3, image 1 of 2 Blackberry Bold 9900 Keyboard Replacement, MicroSD card: step 3, image 2 of 2
    • The MicroSD card is located where the red rectangle is shown.
    • To remove MicroSD card, push the card inward towards the top of the phone then release. The MicroSD card will be ejected.
    Ask FixBot
  4. Blackberry Bold 9900 Keyboard Replacement, Keyboard: step 4, image 1 of 2 Blackberry Bold 9900 Keyboard Replacement, Keyboard: step 4, image 2 of 2
    • Lift the bezel at the bottom of the phone up and peel it away from the phone.
    Ask FixBot
  5. Blackberry Bold 9900 Keyboard Replacement: step 5, image 1 of 2 Blackberry Bold 9900 Keyboard Replacement: step 5, image 2 of 2
    • Remove the two exposed screws using the T5 Torx screwdriver.
    Ask FixBot
  6. Blackberry Bold 9900 Keyboard Replacement: step 6, image 1 of 1
    • Now lever the keyboard up using the screwdriver in the indicated hole.
    Ask FixBot
  7. Blackberry Bold 9900 Keyboard Replacement: step 7, image 1 of 2 Blackberry Bold 9900 Keyboard Replacement: step 7, image 2 of 2
    • The keyboard is attached via a ribbon cable. Pull the cable up to remove the keyboard.
    Ask FixBot
2 other people completed this guide.
Chris Velasquez
235 Reputation
2 Guides authored
Baylor, Team S1-G4, Johnson Spring 2018 Member of Baylor, Team S1-G4, Johnson Spring 2018
BU-JOHNSON-S18S1G4
3 Members
18 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 10
Past 30 Days: 75
All Time: 2,482
