Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
The Atari Flashback 2 Will Not Power On
The Device does nothing when turned on and plugged into TV
The Device is Not Plugged In
Please check if the Atari Flashback 2 is connected to a power source (power cable is securely plugged in to outlet).
The Power Cable is Physically Damaged
If the power cable shows signs of excessive wear or if the power cable is showing bare wire, you may need to replace the power cable.
The Power Socket on Console is Physically Damaged
Inspect the power socket for broken components. If the power socket shows signs of being physically broken, you may need to replace the power socket on the device.
The Joystick Provides Diminished or No Input
Nothing happens on the screen when the joystick is moved
The Joystick is Not Securely Connected
Try reconnecting the joystick to the console.
The Joystick is Obstructed
The joystick may have been dislodged from the correct position or have something obstructing its movement. Inspect the joystick to confirm nothing is obstructing its movement.
The Joystick is Damaged
Inspect the joystick for physical damage. If the joystick shows signs of physical damage, you may need to replace the joystick. Please see this guide to learn how to replace the joystick.
The Joystick Button Provides Diminished or No Input
Nothing happens when the button on the joystick is pushed
The Joystick May Not be Securely Connected to the Console
Joystick Button is Obstructed
The joystick button may have been dislodged from correct position or have something obstructing it's movement. Clean the joystick button with compressed air to assure that it is not being jammed with debris.
The Joystick Button is Damaged
Inspect the joystick button for physical damage. If the joystick button shows signs of physical damage, please see this guide to learn how to replace the joystick button.
The Console Buttons Provide Diminished or No Input
Nothing happens when the button on the console is pushed
Make sure that the console is plugged into a power source securely. Try reconnecting power cable from the console to power source.
The Console Button is Obstructed
The console button may have been dislodged from correct position or have something obstructing it's movement. Clean the console button with compressed air to assure that it is not being jammed with debris.
The Console Button is Damaged
Inspect the console button for physical damage. If the console button shows signs of physical damage, please see one of the following guides to learn how to replace the console button.
Power Button
Reset and Select Button
Difficulty Button
There is No Audio or Video
Nothing is displayed on the TV screen or there is no sound coming out
The TV is On and Set to the Correct Input
Check that the TV is set to correct channel/input on your TV respective to the AV cable output.
The TV Volume is Low or Muted
Check that the TV volume is not muted or at too low of a volume to be heard.
The AV Cable is Not Securely Connected
Reconnect the AV cable from the TV to the console.
The AV Cable May be Dirty and/or Need to be Cleaned
Inspect AV cable for corrosion/oxidation. If debris is present on the cables, clean the plugs and outlets with compressed air, ensuring all surfaces are free from debris.
The AV Cable is Physically Damaged
If the AV cable shows signs of excessive wear or if the cable is showing bare wire, you may need to replace the AV cable.
Author
with
Aaron Ramadan
135 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 31
All Time: 4,419
