Up to 20% off select tools
Atari Flashback 2 Joystick Button Replacement
Views: 1.2K
View statistics:
Past 24 Hours:
3
Past 7 Days:
21
Past 30 Days:
78
All Time:
1,177
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 5 - 20 minutes
Difficulty: Easy
Tools
  • Spudger
    4.9
  • Phillips #1 Screwdriver
    5
Introduction
Go to step 1 ↓
If the button on an Atari Flashback 2 joystick is sticking or broken, then it will need to be cleaned or replaced. This guide covers the steps necessary to disassemble the joystick in order to access the button to do so efficiently.
    1. Atari Flashback 2 Joystick Button Replacement, Joystick Button: step 1, image 1 of 1
      • Using the screwdriver and the PH1 bit, unscrew the four 10.0 mm screws on the bottom of the joystick.
      • Remove the bottom panel from the joystick.
      Ask FixBot
    2. Atari Flashback 2 Joystick Button Replacement: step 2, image 1 of 1
      • Unscrew the single 8.0 mm Phillips#1 screw holding the circuit board in place.
      • Remove the circuit board from the joystick housing.
      Ask FixBot
    3. Atari Flashback 2 Joystick Button Replacement: step 3, image 1 of 1
      • Inspect the circuit board for dirt, corrosion or damage. If necessary, clean the indicated contact using a cotton swab.
      Ask FixBot
    4. Atari Flashback 2 Joystick Button Replacement: step 4, image 1 of 1
      • Remove the button from the joystick housing. Check for dirt or debris that may obstruct its movement. If the button is broken, replace it.
      Ask FixBot
Author
with
Daniel Hoffman
209 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 21
Past 30 Days: 78
All Time: 1,177
