Up to 20% off select tools
Atari Flashback 2 Difficulty Button Replacement
View statistics:
Past 24 Hours:
Past 7 Days:
12
Past 30 Days:
70
All Time:
992
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 5 - 15 minutes
Difficulty: Easy
Tools
Introduction
Go to step 1 ↓
If the difficulty button on an Atari Flashback 2 console is sticking or broken, then it will need to be cleaned or replaced. This guide covers the steps necessary to disassemble the console in order to access the buttons for replacement.
    1. Atari Flashback 2 Difficulty Button Replacement, Difficulty Button: step 1, image 1 of 3 Atari Flashback 2 Difficulty Button Replacement, Difficulty Button: step 1, image 2 of 3 Atari Flashback 2 Difficulty Button Replacement, Difficulty Button: step 1, image 3 of 3
      • Using the screwdriver and the PH1 bit, unscrew the five 10.0 mm screws on the bottom of the console.
      • One screw is under the main sticker in the middle of the console.
      Ask FixBot
    2. Atari Flashback 2 Difficulty Button Replacement: step 2, image 1 of 2 Atari Flashback 2 Difficulty Button Replacement: step 2, image 2 of 2
      • Unscrew the two 10.0 mm Phillips #1 screws, and gently pull back the green circuit board.
      • Remove gently. The circuit board is connected by wire to the board. Removing the cable from the console case may allow more slack.
      • The button springs may be under compression.
      Ask FixBot
Author
with
Aaron Ramadan
135 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 12
Past 30 Days: 70
All Time: 992
