Up to 20% off select tools
Atari Flashback 2 Reset and Select Button Replacement
Views: 1.7K
View statistics:
Past 24 Hours:
3
Past 7 Days:
18
Past 30 Days:
77
All Time:
1,690
Comments: 2
2 guide comments.
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 30 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
If the button on an Atari Flashback 2 console is sticking or broken, then it will need to be cleaned or replaced. This guide covers the steps necessary to disassemble the console in order to access the buttons to do so.
    1. Atari Flashback 2 Reset and Select Button Replacement, Reset or Select Button: step 1, image 1 of 3 Atari Flashback 2 Reset and Select Button Replacement, Reset or Select Button: step 1, image 2 of 3 Atari Flashback 2 Reset and Select Button Replacement, Reset or Select Button: step 1, image 3 of 3
      • Using the screwdriver and the PH1 bit, unscrew the five 10.0 mm screws on the bottom of the console.
      • One screw is under the main sticker in the middle of the console.
      Ask FixBot
    2. Atari Flashback 2 Reset and Select Button Replacement: step 2, image 1 of 3 Atari Flashback 2 Reset and Select Button Replacement: step 2, image 2 of 3 Atari Flashback 2 Reset and Select Button Replacement: step 2, image 3 of 3
      • Unscrew the six 9.0 mm Phillips #1 screws on the brown circuit board that correspond to the reset and select buttons.
      • Remove gently. The circuit board is connected by wire to the console. Removing the cable from the console case may allow more slack.
      Ask FixBot
Author
with
Gabriel Robinson
85 Reputation
1 Guide authored
2 Guide Comments
Good night! I have a flashback2 atari which burst the capacitor EC1, could you help me with its value? Thank you!
pradose - Reply Share
Hi pradose! We no longer have the device so it will not be possible for our team to walk you through anything beyond the guides we posted.
Daniel Hoffman - Reply Share
Past 24 Hours: 3
Past 7 Days: 18
Past 30 Days: 77
All Time: 1,690
