Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
Laptop will not turn on
When plugged in to the power adapter, your Asus X751L will not turn on
Faulty Power Adapter
If the power light is off, the adapter and/or the power cord are not functioning correctly. Check if any connections with the adapter and the power cord are loose. Check if there are any damages to the adapter or the power cord. Try charging with a new adapter and a power cord.
Defective Battery
If the power light is on, the adapter and the power cord are functioning correctly and the issue is likely with the major components. Remove the battery and all external devices (USB, memory card, HDMI cables etc.) to directly provide power supply to charge. If the laptop boots up properly, the battery may no longer be functioning correctly and needs to be replaced.
Audio Distortion
You have trouble listening to sounds on your laptop.
Loose Headphone Jack
Test audio through the computer speakers, then test it using an external audio device. If the audio is only distorted while listening via external audio device, the the audio jack or the external audio device themselves may be faulty. Audio may be distorted by loose connection with the audio jack.
Faulty Driver
If the audio sound is distorted when listening through the laptop’s speakers, the audio driver may be corrupt or outdated. Check out the ASUS driver page and select the appropriate operating system (OS). Select AUDIO and click on the latest RealTek Audio Driver that is appropriate to your computer. Restart computer and check the laptop's speakers again.
Failure to Read CD's and DVD's
Your Asus X751L will not read any CDs or DVDs.
Incompatible disc
Check to make sure the optical drive in the laptop has the ability to read the disc. Standard versions of laptop only come with Super-Multi DVD optical drives. Check the ASUS X751L product page for further details.
Broken/Defective Optical Drive
If your Asus X751L optical drive does not open or does not read CDs or DVDs, the optical drive may be broken and needs to be replaced.
Screen is black
When powered on, your Asus X751L screen doesn't show an image
Computer in sleep mode
Check power button light or front left edge of laptop, if indicator light is blinking then laptop is in sleep mode. Click the left mouse button or click the power button and wait approximately 5 - 10 seconds for screen to light up. If no image appears on screen then the screen may need to be replaced.
LCD display disabled
Check if the display is disabled by pressing and holding the fn key on the bottom left side of the keyboard and then simultaneously pressing the F7 key. Screen should light up and display image.
Laptop Overheating
When the laptop is running for a period of time, the laptop feels hot or/and the fan makes odd noises
Broken/Defective Cooling Fan
Check the air vents while computer is running and note the measure of air flow and temperature through the vents. If there is little air flow and/or is hot the air vents may have accumulated dust and debris which restricts air flow. Use compressed air to gently blow out the debris and dust. If problems persist, the fan needs to be replaced.
Old Parts
Defective batteries may become inefficient with energy transfer and generate heat. The battery may need to be replaced. Heavy processing load may cause components to overheat. Load may be reduced by trimming intensive programs through Windows Task Manager. If problems persist, the processor may need to be replaced.
No Wireless Connection
When the laptop is turned on, you cannot access the Internet.
Airplane mode is on
If airplane mode is turned on, you won't have a wireless connection. In order to turn airplane mode off, press the fn button on the lower left side of the keyboard and simultaneously press F2. This will turn airplane mode off.
Broken/Defective Wireless Card
A broken or defective wireless card can cause issues with connecting to the internet. If you have no wireless connection and airplane mode is turned off, you may have to replace the wireless card.
No Input On Key Press
When you press a key there is no feedback on the laptop, or the key does not fully depress.
Jammed Key
If you can't fully depress a key, you may need to clean underneath the key. To do this, simply use a plastic opening tool to pop the key off. Clean underneath the key and then replace the key.
Broken/Defective Keyboard
A broken or defective keyboard can cause typing issues and the laptop not registering key presses. If no key presses are being registered, you may have to replace the keyboard.
Author
with
Carl Ravina
125 Reputation
1 Guide authored
USF Tampa, Team 17-2, Blackwell Spring 2017 Member of USF Tampa, Team 17-2, Blackwell Spring 2017
USFT-BLACKWELL-S17S17G2
4 Members
60 Guides authored
3 Comments
I'm having issues with the audio cutting out after 10 to 15 minutes. Using the audio troubleshooting pathway, I get a temporary fix. However, the problem returns and can't be fixed with troubleshooting. I do a reboot and then start over with the issue. What other fixes are there?
hacox@yahoo.com
Hesley Cox - Reply Share
Hi i need some help i try the power adapter and batery and that still can't boot i ave no led when i press the power or when its plug on the power , HDD is okey and the rest i can't test .. Well thx ^ ^
Benoit gamer - Reply Share
I was typing away and instantly the laptop shut off. Repeated attempts only turned it on for a moment and then it shut down. I let it sit for a bit, and it started to windows updating. The update got to 19% and it shut down again. I left it alone again and came back. It got to 19% again and shut down. The battery was almost fully charged. The green and orange lights come on. The ASUS logo comes up. A couple times Program Automatic Repair comes up and then the laptop shuts off again. I am not sure what to do now. Apparently ASUS won’t recognize this model. Any help would be appreciated. bassbro1@gmail.com
bassbro1 - Reply Share
Past 24 Hours: 2
Past 7 Days: 8
Past 30 Days: 38
All Time: 3,191
