Up to 20% off select tools
Asus X751L Battery Replacement
Views: 15K
View statistics:
Past 24 Hours:
13
Past 7 Days:
53
Past 30 Days:
277
All Time:
15,310
Comments: 7
1 comment on steps, 6 guide comments.
Go to guide comments
Completed: 5
5 people have marked this guide "completed." Will you be next?
Favorites: 3
3 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 15 minutes
Difficulty: Easy
Fix Kit
This kit contains all the parts and tools needed to complete this guide.
Parts
Tools
Introduction
Go to step 1 ↓
This guide will walk you through the process of replacing a broken or faulty battery on the Asus X751L.
    1. Asus X751L Battery Replacement, Keyboard: step 1, image 1 of 1
      • With the screen closed, place your laptop upside-down with the front facing you.
      • Remove the six 14.6mm Phillips #00 screws.
      • Remove the four 6.6mm Phillips #00 screws.
      Ask FixBot
    2. Asus X751L Battery Replacement: step 2, image 1 of 1
      • Flip the laptop over and open the lid.
      • Pry around the edges of the laptop base using the plastic opening tool.
      • Prying too hard can break the plastic clips.
      Ask FixBot
    3. Asus X751L Battery Replacement: step 3, image 1 of 3 Asus X751L Battery Replacement: step 3, image 2 of 3 Asus X751L Battery Replacement: step 3, image 3 of 3
      • Carefully lift the keyboard up.
      • Be very careful when lifting the keyboard up. Two zero insertion force (ZIF) cables are between the keyboard assembly and the motherboard. Do not lift the assembly too high.
      • Disconnect the two ZIF connectors from the motherboard using your fingernail to lift the cream-colored tab.
      Ask FixBot
    1. Asus X751L Battery Replacement, Battery: step 4, image 1 of 1
      • Remove the two 6.6mm Phillips #00 screws holding the battery in place.
      Ask FixBot
    2. Asus X751L Battery Replacement: step 5, image 1 of 2 Asus X751L Battery Replacement: step 5, image 2 of 2
      • Lift the battery from the cable-side to maneuver it around the plastic clips.
      Ask FixBot
    3. Asus X751L Battery Replacement: step 6, image 1 of 3 Asus X751L Battery Replacement: step 6, image 2 of 3 Asus X751L Battery Replacement: step 6, image 3 of 3
      • Using your finger nails, gently push the battery cable out of the connector on the motherboard.
      • Once the cable is disconnected, you can remove the battery.
      Ask FixBot
5 other people completed this guide.
Author
with
John Enderton
612 Reputation
2 Guides authored
USF Tampa, Team 17-2, Blackwell Spring 2017 Member of USF Tampa, Team 17-2, Blackwell Spring 2017
USFT-BLACKWELL-S17S17G2
4 Members
60 Guides authored
6 Guide Comments
Very nice, thank you !
anh
barzamjavel - Reply Share
very nice, thank you !
Anh
Took me awhile to figure out how to get the cables back. Other than that, good insturctions.
Jacqueline Foxall - Reply Share
Your instructions were easy to follow. Thank you!!!
theresa collet - Reply Share
very helpful
khan - Reply Share
Past 24 Hours: 13
Past 7 Days: 53
Past 30 Days: 277
All Time: 15,310
