Up to 20% off select tools
Asus X751L Keyboard Replacement
Views: 4.2K
View statistics:
Past 24 Hours:
5
Past 7 Days:
33
Past 30 Days:
138
All Time:
4,167
Comments: 1
1 guide comment.
Go to guide comments
Completed: 3
3 people have marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 10 minutes
Difficulty: Easy
Tools
Introduction
Go to step 1 ↓
This guide will walk you through the process of replacing a broken or faulty keyboard on the Asus X751L.
    1. Asus X751L Keyboard Replacement, Keyboard: step 1, image 1 of 1
      • With the screen closed, place your laptop upside-down with the front facing you.
      • Remove the six 14.6mm Phillips #00 screws.
      • Remove the four 6.6mm Phillips #00 screws.
      Ask FixBot
    2. Asus X751L Keyboard Replacement: step 2, image 1 of 1
      • Flip the laptop over and open the lid.
      • Pry around the edges of the laptop base using the plastic opening tool.
      • Prying too hard can break the plastic clips.
      Ask FixBot
    3. Asus X751L Keyboard Replacement: step 3, image 1 of 3 Asus X751L Keyboard Replacement: step 3, image 2 of 3 Asus X751L Keyboard Replacement: step 3, image 3 of 3
      • Carefully lift the keyboard up.
      • Be very careful when lifting the keyboard up. Two zero insertion force (ZIF) cables are between the keyboard assembly and the motherboard. Do not lift the assembly too high.
      • Disconnect the two ZIF connectors from the motherboard using your fingernail to lift the cream-colored tab.
      Ask FixBot
3 other people completed this guide.
Author
with
John Enderton
612 Reputation
2 Guides authored
USF Tampa, Team 17-2, Blackwell Spring 2017 Member of USF Tampa, Team 17-2, Blackwell Spring 2017
USFT-BLACKWELL-S17S17G2
4 Members
60 Guides authored
1 Guide Comment
Looks easy enough, I have a Polish version qwertz keyboard , a 752L model-17" anyone know a compatible UK qwerty keyboard as a replacement? - or or a k. board shared with another model that will fit ? Asus service centre are less than helpful .!
phil.kath4 - Reply Share
Past 24 Hours: 5
Past 7 Days: 33
Past 30 Days: 138
All Time: 4,167
