Up to 20% off select tools
Asus X751L DVD Drive Replacement
Views: 3.1K
View statistics:
Past 24 Hours:
3
Past 7 Days:
22
Past 30 Days:
102
All Time:
3,142
Comments: 1
1 guide comment.
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 15 minutes
Difficulty: Very easy
Tools
Introduction
Go to step 1 ↓
This guide will will walk you through the process of removing and replacing a faulty DVD Drive.
    1. Asus X751L DVD Drive Replacement, Keyboard: step 1, image 1 of 1
      • With the screen closed, place your laptop upside-down with the front facing you.
      • Remove the six 14.6mm Phillips #00 screws.
      • Remove the four 6.6mm Phillips #00 screws.
      Ask FixBot
    2. Asus X751L DVD Drive Replacement: step 2, image 1 of 1
      • Flip the laptop over and open the lid.
      • Pry around the edges of the laptop base using the plastic opening tool.
      • Prying too hard can break the plastic clips.
      Ask FixBot
    3. Asus X751L DVD Drive Replacement: step 3, image 1 of 3 Asus X751L DVD Drive Replacement: step 3, image 2 of 3 Asus X751L DVD Drive Replacement: step 3, image 3 of 3
      • Carefully lift the keyboard up.
      • Be very careful when lifting the keyboard up. Two zero insertion force (ZIF) cables are between the keyboard assembly and the motherboard. Do not lift the assembly too high.
      • Disconnect the two ZIF connectors from the motherboard using your fingernail to lift the cream-colored tab.
      Ask FixBot
    1. Asus X751L DVD Drive Replacement, DVD Drive: step 4, image 1 of 1
      • With the keyboard panel open, face the laptop with the internal components facing towards you.
      • Remove the single 4.6mm Phillips #00 screw.
      Ask FixBot
    2. Asus X751L DVD Drive Replacement: step 5, image 1 of 1
      • Pull the optical drive out.
      Ask FixBot
2 other people completed this guide.
Author
with
Carl Ravina
125 Reputation
1 Guide authored
USF Tampa, Team 17-2, Blackwell Spring 2017 Member of USF Tampa, Team 17-2, Blackwell Spring 2017
USFT-BLACKWELL-S17S17G2
4 Members
60 Guides authored
1 Guide Comment
Spot on, took away any worries…………
paul pepper - Reply Share
Past 24 Hours: 3
Past 7 Days: 22
Past 30 Days: 102
All Time: 3,142
