Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
Padfone x mini Won't Dock Correctly
You have trouble docking your Padfone x mini to the tablet docking station.
Faulty Placement
Check to make sure that you are sliding your Padfone x mini correctly into the tablet's docking station. Turn your tablet over so that the screen is facing down to reveal the docking port on the back. Turn your Padfone x mini over so that the screen is face down as well. Slide the Padfone x mini into the tablet's docking bay face down. The side panels should hug the phone as it goes into the port. Make sure you push it all the way down to guarantee a complete connection. Flip the tablet over, and confirm that the display is working correctly.
Faulty Docking Pins on the Tablet
The tablet that accompanies the Padfone x mini has a micro USB port that sticks out of the bottom of the phone bay. The port is used to connect the Padfone x mini to the tablet's screen. If a few pins are bent in the wrong direction, it may be the reason why you are having docking issues. If you need help on how to get your Padfone x mini's pins fixed, check out this guide.
Faulty Docking Pins on the Padfone x mini
The Padfone x mini has its own micro USB port so that it can connect to the tablet. Look at the underside of the phone to check for the port. If a few pins are bent in the wrong direction, it may be the reason why you are having docking issues. If you need help on how to get your tablet's pins fixed, check out this guide.
Black Screen When Taking Pictures
When you try to take a picture, the screen is black or fuzzy.
Camera Lens is Covered or Dirty
Check to make sure that the camera lens isn't covered when you are trying to take a picture. Remove the object covering the lens, and clean the lens with a paper towel or a moist towelette.
Faulty Camera
If your camera is still not working then you are going to need to replace your phone camera. To replace the camera, follow this guide.
Black Spots on Screen/Image Distortion/No Image
Screen is either cracked, chipped, shattered, or has dead pixels.
Cracked Screen
If you have a screen protector on your Padfone x mini, take it off to see if the crack or chip was on the actual screen. If so, you will need to replace your phone screen. Follow this guide to see how to replace it.
Dead Pixels
If you turn on your phone and there are either black lines or circles, or it is discolored anywhere, it could mean you have dead pixels. This could happen from the screen being cracked or "bruised", which means that the exterior of the screen is fine, but there is damage to the interior portion of the screen. If this is the problem, go to this guide to see how to fix it.
Padfone x mini Not Turning On/Charging
The screen is black when you try turning on the device, and the phone does not hold a charge.
Charger Placement
Make sure that the charger is inserted completely into the Padfone x mini. If the adapter is not inserted all the way, push it in until it clicks, and check to see if the phone has started charging.
Defective SIM Card
If the device starts to reboot on its own, wait until the phone is accessible, and make sure that no data on the device has been lost. Next, take the SIM card out of the device, and check that there are no defects with it. If there are no defects on the SIM card, then you can go into your settings, and look for any updates that are needed for your Padfone x mini.
Dead Battery
If you have tried all of the steps above, and the phone is still not turning on, you might have a dead battery. Another sign of a dead battery is if your Padfone x mini cannot function without being connected to a charger. This means your battery has died, and you need to replace it with a new one. To replace your battery, follow [invalid guide link]
No Audio/ Audio is Fuzzy
You cannot hear any sound coming out of the speaker, or the audio is distorted.
Sound is not Turned on
The volume of the Padfone x mini may not be turned on. To turn on the volume, press the "+" button on the right side of the phone.
Speaker is Covered
Make sure nothing is covering the speaker located at the top of the screen. If the speaker is covered, remove whatever is covering it.
Speaker is Broken
You can check to see if the speaker is broken if you are trying to play something, and there is no audio coming from your phone. The speaker may also be broken if you are trying to play something, and the audio is muffled or unclear. If this is the case, you will need to replace your phone's speaker. To replace the speaker, use this guide.
Author
with
Nicolette Carr
428 Reputation
2 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 7
Past 30 Days: 14
All Time: 635
