Up to 20% off select tools
Asus Padfone X Mini Screen Replacement
View statistics:
Past 24 Hours:
9
Past 7 Days:
19
Past 30 Days:
66
All Time:
798
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 5 - 10 minutes
Difficulty: Moderate
Better Introduction
Improve this guide by completing or revising its introduction.
Tools
    1. Asus Padfone X Mini Screen Replacement, Speaker: step 1, image 1 of 1
      • With the phone facing down, look at the bottom right side corner and there should be a groove. Use a plastic opening tool and lift up to remove outside cover.
      • This is not the cover with the speaker attached.
      Ask FixBot
    2. Asus Padfone X Mini Screen Replacement: step 2, image 1 of 1
      • Lift the battery out from the top of the device.
      Ask FixBot
    3. Asus Padfone X Mini Screen Replacement: step 3, image 1 of 1
      • Around the perimeter, there should be 10 2 mm T5 Torx screws. Take them out.
      • Remove the cover.
      Ask FixBot
    4. Asus Padfone X Mini Screen Replacement: step 4, image 1 of 1
      • Turn the cover over.
      • The speaker is attached to the inside of the cover and to the right of the camera hole.
      Ask FixBot
    5. Asus Padfone X Mini Screen Replacement: step 5, image 1 of 1
      Tool used on this step:
      Buy
      • Remove speaker with standard tweezers to minimize damage, and replace.
      Ask FixBot
    1. Asus Padfone X Mini Screen Replacement, Screen: step 6, image 1 of 1
      • Detach the black connector on the left hand side of the motherboard.
      • Don't completely remove the black connector.
      Ask FixBot
    2. Asus Padfone X Mini Screen Replacement: step 7, image 1 of 1
      • Disconnect silver connector from the motherboard. It is located on the left hand side above the black connector.
      Ask FixBot
    3. Asus Padfone X Mini Screen Replacement: step 8, image 1 of 2 Asus Padfone X Mini Screen Replacement: step 8, image 2 of 2
      • Remove motherboard and replace screen.
      Ask FixBot
Author
with
Benjamin Trigg
97 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 9
Past 7 Days: 19
Past 30 Days: 66
All Time: 798
