Asus Padfone X Mini Speaker Replacement
  1. Asus Padfone X Mini Speaker Replacement, Speaker: step 1, image 1 of 1
    • With the phone facing down, look at the bottom right side corner and there should be a groove. Use a plastic opening tool and lift up to remove outside cover.
    • This is not the cover with the speaker attached.
  2. Asus Padfone X Mini Speaker Replacement: step 2, image 1 of 1
    • Lift the battery out from the top of the device.
  3. Asus Padfone X Mini Speaker Replacement: step 3, image 1 of 1
    • Around the perimeter, there should be 10 2 mm T5 Torx screws. Take them out.
    • Remove the cover.
  4. Asus Padfone X Mini Speaker Replacement: step 4, image 1 of 1
    • Turn the cover over.
    • The speaker is attached to the inside of the cover and to the right of the camera hole.
  5. Asus Padfone X Mini Speaker Replacement: step 5, image 1 of 1
    Tool used on this step:
    Buy
    • Remove speaker with standard tweezers to minimize damage, and replace.
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 43
All Time: 370
