Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
Laptop Won't Turn On
The laptop will not power on when opened or when pressing the power button.
Adapter Not Charging Laptop
  • Make sure that the adapter is plugged into the laptop. If it is, check that the adapter light is turning on. If it isn't, then the cable is likely faulty and it should be replaced.
  • Try a combination of plugging the adapter into another computer and into another outlet. If these do not solve the problem, the cable must be replaced. If the adapter works with another computer and with the same outlet, the charging port on your laptop is faulty.
Dead/Uncharged Battery
  • After verifying that the adapter is not the problem, move on to checking if the battery is at fault.
  • Remove the battery from the laptop, and attempt to power on the laptop while it is plugged in. If this solves the issue, then the battery is faulty and must be replaced.
For a step-by-step guide for removing/replacing the battery, click here.
Unresponsive Keyboard
If the keys are unresponsive in some way, or key presses are not registered.
Keys Unresponsive/Can't Be Pressed
  • If a certain key is unresponsive, it may only be necessary to clean the individual key. If it is only an individual key, try taking the button off the keyboard and cleaning out any residue that may be there.
For a step-by-step guide for removing the keyboard, click here.
Keyboard Entirely Unresponsive
  • Replacing the entire keyboard is necessary after exhausting the step for cleaning out keys that are unresponsive. If one or many keys are still not responding to being pressed, replacing the entire keyboard is required.
For a step-by-step guide for taking apart the keyboard, click here.
Trackpad/Buttons are Unresponsive
If the trackpad does not respond to movement or the buttons do not respond to being clicked.
No Movement From Trackpad
  • If the trackpad is not responding to movement, check to see if the ribbon cable has become dislodged. If not, it may necessary to replace the entire trackpad and ribbon cable. If the cable has in fact become dislodged, try reconnecting it and testing the trackpad again.
For a step-by-step guide for removing the trackpad and checking the ribbon cable, click here.
Buttons Unresponsive/Will Not Click
  • If either of the buttons (left-click or right-click) are unresponsive, check the connection of the ribbon cable under the trackpad. If the cable is connected and still unresponsive, the entire trackpad and ribbon cable must be replaced. If the cable is disconnected, try connecting it and re-testing the buttons.
For a step-by-step guide for removing the trackpad, click here.
Decreased Performance
The computer has become noticeably slower.
Insufficient RAM
  • If the computer has become noticeably slower, it is possible that you may not have enough RAM. If you run out of RAM, increasing the amount that you have installed will help your computer to be more efficient.
  • If you get the infamous "blue screen of death" or you have noticed a number of files becoming corrupt, it is possible that the installed RAM stick is faulty and must be replaced.
For a step-by-step guide for replacing the RAM, click here.
Data Corruptions
Files becoming corrupted or read-only, computer crashes during boot.
Corrupt SSD
  • If there are files on your computer that cannot be read or cannot be written to, this is a sign of a failing SSD, and it will need to be replaced soon.
  • If the PC won't boot up (Operating System will not load), this is also a sign that the SSD is failing and will need to be replaced.
For a step-by-step guide for replacing the SSD, click here.
Vinny Micale
225 Reputation
2 Guides authored
2 Comments
I own the eee 701, had bought it several years ago new but never used it. Recently I recharged it and turned it on but the screen has bad flickering and is divided into two halves, being totally unusable. Any ideas as to how to fix it?
Mr_Mr - Reply Share
Did you ever find out how to fix this issue?
Sean Rembert - Reply Share
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 14
All Time: 961
