ASUS EEE PC701SD-WHI004X Keyboard Replacement
    1. ASUS EEE PC701SD-WHI004X Keyboard Replacement, Battery: step 1, image 1 of 2 ASUS EEE PC701SD-WHI004X Keyboard Replacement, Battery: step 1, image 2 of 2
      • Flip the laptop over, you should see two battery tabs.
      • Slide the right tab towards the right. The orange dot should be visible. This tab will be locked open.
      Ask FixBot
    2. ASUS EEE PC701SD-WHI004X Keyboard Replacement: step 2, image 1 of 2 ASUS EEE PC701SD-WHI004X Keyboard Replacement: step 2, image 2 of 2
      • While holding the left tab towards the left. Gently slide the battery out of the laptop.
      Ask FixBot
    1. ASUS EEE PC701SD-WHI004X Keyboard Replacement, Keyboard: step 3, image 1 of 3 ASUS EEE PC701SD-WHI004X Keyboard Replacement, Keyboard: step 3, image 2 of 3 ASUS EEE PC701SD-WHI004X Keyboard Replacement, Keyboard: step 3, image 3 of 3
      • Push the 3 tabs at the top of the keyboard in and down one at a time using a nylon spudger.
      • Once the three tabs have been pushed in, gently pry the top of the keyboard until it begins to hinge out of its slot.
      • The keyboard is still attached by a cable. Be careful when removing not to damage the cable. Do not yank the keyboard out.
      Ask FixBot
    2. ASUS EEE PC701SD-WHI004X Keyboard Replacement: step 4, image 1 of 3 ASUS EEE PC701SD-WHI004X Keyboard Replacement: step 4, image 2 of 3 ASUS EEE PC701SD-WHI004X Keyboard Replacement: step 4, image 3 of 3
      • Push the two sides of the ribbon cable connector away from yourself. This will unseat the ribbon cable.
      • Once the tabs are unseated, you can gently remove the ribbon cable by pulling it out of its slot. The keyboard can now be removed.
      • To be on the safe side, it’s better to use a nylon spudger, rather than the metal spudger shown in the picture.
      Ask FixBot
mir
409 Reputation
3 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 39
All Time: 978
