Tools
Introduction
Go to step 1 ↓Use this guide to replace the RAM of your ASUS EEE PC701SD-WHI004X. Be sure to disconnect the laptop from all sources of power before beginning. You should follow this guide if you have noticed a drop in the performance of your laptop.
Flip the laptop over, you should see two battery tabs.
Slide the right tab towards the right. The orange dot should be visible. This tab will be locked open.
Remove the two 2.5mm Phillips #1 screws.
Remove back panel by lifting the tab, this will expose the RAM.
