Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
Amazon FireTV Stick Not Recognized by Device
There is a Blank screen on my TV or my device is not responding to the Amazon FireTV stick
Loose Physical Connection or Low Power
Double check that the stick is firmly inserted all the way into your TV's HDMI port. If the fireTV stick still doesn't show up on the device when plugged in, make sure that the stick is fully powered using the provided USB adapter.
Faulty Motherboard
If the Amazon fireTV stick is still not working this may mean the motherboard is faulty and needs to be replaced. Do this only as a last resort.
The guide can be found by clicking on this link. for the remote motherboard.
This guide will go through access and the replacement of the stick motherboard. Click here.
Amazon FireTV Remote Won't Communicate with Stick
Remote does not seem to be working or I have an unresponsive screen
The best thing to start with will be to reboot and re-pair both devices. Power off the Amazon fireTV stick by unplugging it, and powering it back on. Be sure that the Amazon fireTV stick is fully charged, Then hold the home button for 5-10 seconds to pair the remote again.
Low Batteries
Replace the batteries in the remote. Inspect the spring under the battery to ensure that the battery makes full contact with the metal . To access a guide to access the batteries and replacement procedures follow this link.
Faulty Remote Buttons
If the remote buttons seem to be getting stuck or are not working properly, Replace the buttons on the remote. A guide is available by clicking on the following link.
Video but No Sound from Device
My FireTV is showing video but I am getting no sound from my FireTV stick on device
Receiving Device is Muted
Start by making sure the receiving device is not muted by checking the volume settings.
Amazon Fire TV Stick is Not Compatible with External Speakers
The TV stick may not be compatible with external speakers. Try switching your audio settings to default.
Incorrect Audio Settings
To make sure the audio settings on your FireTV stick are correct, go to the Home Screen (Pressing the Home button on the Remote), enter into Settings, select the Dolby Digital Output option and make sure that Dolby Digital Plus is set to off.
Faulty HDMI Port
In order to check that the HDMI port is working properly, try plugging the TV Stick into another device. If there is still no sound, your TV Stick may have a faulty HDMI port.
Author
with
Youssef Abdelshahid
1 Reputation
0 Guides authored
IUPUI, Team 1-2, Renguette SU 2016 Member of IUPUI, Team 1-2, Renguette SU 2016
IUPUI-RENGUETTE-SU16S1G2
5 Members
0 Guides authored
314 Comments
Why is there no answers about the power port? Where the power cable goes: the connection has come off? Where can I get it fixed?
jclewis5 - Reply Share
We still have no audio even with changing the Dolby Digital to off. Sny suggestions?
Jonnie Dorsey - Reply Share
check the bluetooth devices the only thing that should be there is the 1 remote unpair anything you dont recignize…. For some reason mine will randomly pair to some device and when it does I only get the greeting bell and then no sound click or anything
Paul Vasquez - Reply Share
My firestick works in one hdmi on my big TV. I moved it to a different smaller tv many times and it always worked. Out of nowhere it is just a black screen saying no connection on the small tv. What do I do? I've tried unplugging it and both hdmi ports...please help!!!
kozlowski_jillian - Reply Share
Did you get help with your question? I'm having same issue.
denverbodnar - Reply Share
Past 24 Hours: 10
Past 7 Days: 66
Past 30 Days: 272
All Time: 577,799
