Amazon Fire TV Stick Remote Motherboard Replacement
Views: 37K
View statistics:
Past 24 Hours:
5
Past 7 Days:
49
Past 30 Days:
186
All Time:
36,941
Comments: 16
7 comments on steps, 9 guide comments.
Go to guide comments
Completed: 12
12 people have marked this guide "completed." Will you be next?
Favorites: 2
2 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 5 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
This guide takes you step by step through the process required to replace the motherboard of the Amazon Fire TV Stick Remote. This process is not difficult if you stick to this guide.
Tools
    1. Amazon Fire TV Stick Remote Motherboard Replacement, Remote Motherboard: step 1, image 1 of 3 Amazon Fire TV Stick Remote Motherboard Replacement, Remote Motherboard: step 1, image 2 of 3 Amazon Fire TV Stick Remote Motherboard Replacement, Remote Motherboard: step 1, image 3 of 3
      • Use a plastic opening tool to open the battery cover. Apply a small amount of force into the crease.
      • Remove batteries.
      Ask FixBot
    2. Amazon Fire TV Stick Remote Motherboard Replacement: step 2, image 1 of 3 Amazon Fire TV Stick Remote Motherboard Replacement: step 2, image 2 of 3 Amazon Fire TV Stick Remote Motherboard Replacement: step 2, image 3 of 3
      • Use a plastic opening tool to pry off the top black ring.
      Ask FixBot
    3. Amazon Fire TV Stick Remote Motherboard Replacement: step 3, image 1 of 2 Amazon Fire TV Stick Remote Motherboard Replacement: step 3, image 2 of 2
      • Remove the 6mm triangle head screw on the front of the remote.
      Ask FixBot
    4. Amazon Fire TV Stick Remote Motherboard Replacement: step 4, image 1 of 3 Amazon Fire TV Stick Remote Motherboard Replacement: step 4, image 2 of 3 Amazon Fire TV Stick Remote Motherboard Replacement: step 4, image 3 of 3
      • Use two plastic opening tools to pry along the seam of the remote and separate the face plate.
      Ask FixBot
    5. Amazon Fire TV Stick Remote Motherboard Replacement: step 5, image 1 of 3 Amazon Fire TV Stick Remote Motherboard Replacement: step 5, image 2 of 3 Amazon Fire TV Stick Remote Motherboard Replacement: step 5, image 3 of 3
      • Lift the rubber pad from the motherboard.
      Ask FixBot
    6. Amazon Fire TV Stick Remote Motherboard Replacement: step 6, image 1 of 2 Amazon Fire TV Stick Remote Motherboard Replacement: step 6, image 2 of 2
      • Use the opening tool to lift the back of the motherboard. Slowly lift the motherboard while keeping the wires straight.
      Ask FixBot
12 other people completed this guide.
Andrew Busse
945 Reputation
2 Guides authored
IUPUI, Team 2-3, Harley SU 2016 Member of IUPUI, Team 2-3, Harley SU 2016
IUPUI-HARLEY-SU16S2G3
4 Members
48 Guides authored
9 Guide Comments
It hasnt worked from the start dissapointed
Doug Marriott - Reply Share
Hasnt worked from start dissaopointing product
I have had this firestick for quite some time it's something happened it would me put my password in I forgot it and it says no signal what do I do
CINDY BROWN - Reply Share
My firestick wen I plugin any tv it's not detecting n says no signal
Philip Nunes - Reply Share
My firestick wen I put in any of the hdmi port it doesn't detect any of my tv blank screen n no signal can u let me know
Past 24 Hours: 5
Past 7 Days: 49
Past 30 Days: 186
All Time: 36,941
