Up to 20% off select tools
Amazon Fire TV Stick Remote Battery Replacement
Views: 123K
View statistics:
Past 24 Hours:
11
Past 7 Days:
76
Past 30 Days:
263
All Time:
123,380
Comments: 37
2 comments on steps, 35 guide comments.
Go to guide comments
Completed: 7
7 people have marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 5 minutes
Difficulty: Easy
Parts
Tools
Introduction
Go to step 1 ↓
This guide takes you step by step through the process required to replace the batteries of the Amazon Fire TV Stick remote. This task is simple and should not take more than a few minutes. To complete this you will need a plastic opening tool and two new batteries. If you follow the easy steps you will successfully change the remote batteries in your Amazon fireTV stick.
    1. Amazon Fire TV Stick Remote Battery Replacement, Remote Battery: step 1, image 1 of 3 Amazon Fire TV Stick Remote Battery Replacement, Remote Battery: step 1, image 2 of 3 Amazon Fire TV Stick Remote Battery Replacement, Remote Battery: step 1, image 3 of 3
      • Use the plastic opening tool to press into the seam between the remote and battery cover.
      • With the same tool to help pop the batteries out.
      Ask FixBot
    2. Amazon Fire TV Stick Remote Battery Replacement: step 2, image 1 of 1
      • Place two fresh batteries back inside the remote and slide the cover back on.
      • Ensure positive ends of the batteries both point towards the top of the remote.
      Ask FixBot
7 other people completed this guide.
Author
with
Andrew Busse
945 Reputation
2 Guides authored
IUPUI, Team 2-3, Harley SU 2016 Member of IUPUI, Team 2-3, Harley SU 2016
IUPUI-HARLEY-SU16S2G3
4 Members
48 Guides authored
35 Guide Comments
do you have to use amazon batteries...my remote doesn't work with duracell
mtimken - Reply Share
Hey @mtimken ! As far we know, there isnt anything special about Amazon's AAA batteries. Any two *new* AAA batteries should work just fine. Are you certain both of your Duracell batteries are new? Are they rechargeable batteries that need to be charged up fully? Let us know what you find out! Good luck.
Kelsea Weber - Reply Share
That's my question what type of batteries do I need for my Amazon Fire stick
biba.anderson41 - Reply Share
The remote takes two AAA batteries. See the answer to the comment above. In the future, go ahead and post your question in the Answers forum : ifixit.com/answers. You may get an answer faster by posting where all of our community members can see your question. I hope this helps. Happy fixing!
Hello having problem with firestick Remote cant get it to work ? i change batteries still not working?
denise carter - Reply Share
Past 24 Hours: 11
Past 7 Days: 76
Past 30 Days: 263
All Time: 123,380
