Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
My tablet won't turn on
When the power button is pressed on the tablet the device does not respond and turn on.
The tablet is not charged
Plug your tablet into a power source to charge it.
Your tablet needs to be reset
Find the small reset button on located on the back of your tablet. It is labeled "reset," with white letters. It is a small button that requires using either a paperclip or safety pin to press the button inside the hole. Afterwards, press the power button to see if your tablet turns on.
Power button is broken
You will need to replace the power button. View our guide on replacing the power button.
Broken battery
To replace the battery, view our battery replacement guide here.
My tablet won't charge
When the charger is plugged into the tablet the tablet does not charge.
Obstructed pathway
Make sure that the pathway for the charger and the charging port is not obstructed. If it is, remove any obstructions (EX: sand, staples, food, etc...).
Faulty charger
The charger you have may no longer work, check to make sure it is completely plugged in, and that there are no connection issues. If these do not apply, you will need to replace it with a new charger.
My tablet won't produce sound
When the tablet should be playing music or producing a sound effect, no noise comes from the tablet's speaker.
Obstructed pathway
Make sure no objects are in the way of the speaker on the tablet. If any objects are remove them.
The volume is turned off
Press the raise volume button to desired level of sound. The raise volume button has a + symbol on the left-hand side of the tablet.
Volume buttons unresponsive
Make sure there is no obstruction to the volume buttons. If this is not the issue, you may need to replace your volume buttons. View our guide on replacing the volume buttons.
Broken speaker
If all other solutions do not solve your issue, your speaker may be broken. View our guide on replacing the speaker here.
Touchscreen is unresponsive
When touching the screen, the tablet does not respond to any commands
Find the small reset button on located on the back of your tablet. It is labeled "reset," with white letters. It is a small button that requires using either a paperclip or safety pin to press the button inside the hole. Afterwards, turn on the tablet and see if the touchscreen is responsive.
Screen is broken
You will need to replace your touchscreen. View our guide on replacing the touchscreen here.
Author
with
Colton Morgan
93 Reputation
0 Guides authored
USF Tampa, Team 9-1, Leahy Winter 2015 Member of USF Tampa, Team 9-1, Leahy Winter 2015
USFT-LEAHY-W15S9G1
3 Members
60 Guides authored
2 Comments
Apex GS-918 tablet frozen on dopo screen?
Santos Samaniego - Reply Share
Wont. Boot bbbbbbbbbbn
lucasbscott267 - Reply Share
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 15
All Time: 892
