Up to 20% off select tools
APEX AP-GS918 Battery Replacement
Views: 1.3K
View statistics:
Past 24 Hours:
3
Past 7 Days:
18
Past 30 Days:
88
All Time:
1,268
Comments: 1
1 guide comment.
Go to guide comments
Completed: 3
3 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 15 - 30 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
We will show you how to disassemble your tablet in order to access the battery. This replacement guide is helpful if you feel that your battery is faulty and no longer holding charge. Therefore, you need to replace it.
    1. APEX AP-GS918 Battery Replacement, Power/Volume Button: step 1, image 1 of 3 APEX AP-GS918 Battery Replacement, Power/Volume Button: step 1, image 2 of 3 APEX AP-GS918 Battery Replacement, Power/Volume Button: step 1, image 3 of 3
      • To begin, locate the two 4.9mm Phillips #00 screws at the top corners of the case and remove them.
      Ask FixBot
    2. APEX AP-GS918 Battery Replacement: step 2, image 1 of 3 APEX AP-GS918 Battery Replacement: step 2, image 2 of 3 APEX AP-GS918 Battery Replacement: step 2, image 3 of 3
      • Squeeze the plastic opening tool in between the seam where the screen joins the plastic case.
      • Begin separating the bottom of the case from the screen by carefully going around the whole edge of the case and slowly prying it apart.
      • Be careful when separating the lids because the wires holding the speaker to the motherboard are very short.
      Ask FixBot
    3. APEX AP-GS918 Battery Replacement: step 3, image 1 of 2 APEX AP-GS918 Battery Replacement: step 3, image 2 of 2
      Tool used on this step:
      Buy
      • Carefully place the bottom lid next to the screen case. The power/speaker buttons should be visible at the corner of the lid. Remove the buttons with the tweezers.
      Ask FixBot
    1. APEX AP-GS918 Battery Replacement, Battery: step 4, image 1 of 2 APEX AP-GS918 Battery Replacement, Battery: step 4, image 2 of 2
      • Begin removing the black tape covering the motherboard inside the tablet.
      Ask FixBot
    2. APEX AP-GS918 Battery Replacement: step 5, image 1 of 1
      • You will need to desolder the two contact points that connect the battery to the mother board.
      • Make sure to allow ample time (at least 5-8 minutes or more) for the soldering iron to heat up. Otherwise, the solder won't melt.
      • Touch the hot iron to the contact points and gently pull on the wires to loosen them from the solder. They should release easily.
      • Make sure not to touch the contact points after desoldering them because they will remain very hot for a short while afterwards.
      Ask FixBot
    3. APEX AP-GS918 Battery Replacement: step 6, image 1 of 2 APEX AP-GS918 Battery Replacement: step 6, image 2 of 2
      • Using the black nylon spudger, get underneath the battery and begin prying it loose from the rest of the tablet.
      • The tape holding the battery to the tablet has a very strong hold so be prepared for resistance.
      Ask FixBot
3 other people completed this guide.
Author
with
Megan Lozicki
416 Reputation
4 Guides authored
USF Tampa, Team 9-1, Leahy Winter 2015 Member of USF Tampa, Team 9-1, Leahy Winter 2015
USFT-LEAHY-W15S9G1
3 Members
60 Guides authored
1 Guide Comment
bien consejo, creo que es sencillo por todos para seguin estos pasos
harkhoscole - Reply Share
Past 24 Hours: 3
Past 7 Days: 18
Past 30 Days: 88
All Time: 1,268
