Up to 20% off select tools
APEX AP-GS918 Power/Volume Button Replacement
View statistics:
Past 24 Hours:
3
Past 7 Days:
16
Past 30 Days:
91
All Time:
819
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 5 - 10 minutes
Difficulty: Easy
Tools
Introduction
Go to step 1 ↓
In this guide, you will learn the placement of the screws holding the lid together along with a description of how to properly open up the device and remove the power/volume buttons.
    1. APEX AP-GS918 Power/Volume Button Replacement, Power/Volume Button: step 1, image 1 of 3 APEX AP-GS918 Power/Volume Button Replacement, Power/Volume Button: step 1, image 2 of 3 APEX AP-GS918 Power/Volume Button Replacement, Power/Volume Button: step 1, image 3 of 3
      • To begin, locate the two 4.9mm Phillips #00 screws at the top corners of the case and remove them.
      Ask FixBot
    2. APEX AP-GS918 Power/Volume Button Replacement: step 2, image 1 of 3 APEX AP-GS918 Power/Volume Button Replacement: step 2, image 2 of 3 APEX AP-GS918 Power/Volume Button Replacement: step 2, image 3 of 3
      • Squeeze the plastic opening tool in between the seam where the screen joins the plastic case.
      • Begin separating the bottom of the case from the screen by carefully going around the whole edge of the case and slowly prying it apart.
      • Be careful when separating the lids because the wires holding the speaker to the motherboard are very short.
      Ask FixBot
    3. APEX AP-GS918 Power/Volume Button Replacement: step 3, image 1 of 2 APEX AP-GS918 Power/Volume Button Replacement: step 3, image 2 of 2
      Tool used on this step:
      Buy
      • Carefully place the bottom lid next to the screen case. The power/speaker buttons should be visible at the corner of the lid. Remove the buttons with the tweezers.
      Ask FixBot
Author
with
Christopher Wright
130 Reputation
1 Guide authored
USF Tampa, Team 9-1, Leahy Winter 2015 Member of USF Tampa, Team 9-1, Leahy Winter 2015
USFT-LEAHY-W15S9G1
3 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 16
Past 30 Days: 91
All Time: 819
