APEX AP-GS918 Speakers Replacement
    1. APEX AP-GS918 Speakers Replacement, Power/Volume Button: step 1, image 1 of 3 APEX AP-GS918 Speakers Replacement, Power/Volume Button: step 1, image 2 of 3 APEX AP-GS918 Speakers Replacement, Power/Volume Button: step 1, image 3 of 3
      • To begin, locate the two 4.9mm Phillips #00 screws at the top corners of the case and remove them.
      Ask FixBot
    2. APEX AP-GS918 Speakers Replacement: step 2, image 1 of 3 APEX AP-GS918 Speakers Replacement: step 2, image 2 of 3 APEX AP-GS918 Speakers Replacement: step 2, image 3 of 3
      • Squeeze the plastic opening tool in between the seam where the screen joins the plastic case.
      • Begin separating the bottom of the case from the screen by carefully going around the whole edge of the case and slowly prying it apart.
      • Be careful when separating the lids because the wires holding the speaker to the motherboard are very short.
      Ask FixBot
    3. APEX AP-GS918 Speakers Replacement: step 3, image 1 of 2 APEX AP-GS918 Speakers Replacement: step 3, image 2 of 2
      Tool used on this step:
      Buy
      • Carefully place the bottom lid next to the screen case. The power/speaker buttons should be visible at the corner of the lid. Remove the buttons with the tweezers.
      Ask FixBot
    1. APEX AP-GS918 Speakers Replacement, Speakers: step 4, image 1 of 3 APEX AP-GS918 Speakers Replacement, Speakers: step 4, image 2 of 3 APEX AP-GS918 Speakers Replacement, Speakers: step 4, image 3 of 3
      • The speaker is attached to the bottom lid with with a small amount of glue and the wires are soldered to the motherboard.
      • In order to remove the speaker you will have to desolder the wires connected to the motherboard.
      • Start by peeling back the black electrical tape covering the motherboard components
      • You will also need to remove the black cloth tape covering the wire contact points.
      Ask FixBot
    2. APEX AP-GS918 Speakers Replacement: step 5, image 1 of 2 APEX AP-GS918 Speakers Replacement: step 5, image 2 of 2
      • Now that the contacts are exposed, you can desolder them.
      • Make sure to allow ample time (at least 5-8 minutes or more) for the soldering iron to heat up. Otherwise, the solder won't melt.
      • Touch the hot iron to the contact points and gently pull on the wires to loosen them from the solder. They should release easily.
      • Make sure not to touch the contact points after desoldering them because they will remain very hot for a short while afterwards.
      • The speaker can now be removed. You may need to pull it with some force since there is a small bead of hot glue holding the speaker to its housing
      Ask FixBot
Megan Lozicki
416 Reputation
4 Guides authored
USF Tampa, Team 9-1, Leahy Winter 2015 Member of USF Tampa, Team 9-1, Leahy Winter 2015
USFT-LEAHY-W15S9G1
3 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 9
Past 30 Days: 34
All Time: 576
