Up to 20% off select tools
Models
A3257 US, A3525 CA/MX/JP/SA, A3526 Global, A3527 China
Background
The iPhone 17 Pro Max was announced on September 9th, 2025 alongside the iPhone Air, 17, and 17 Pro. It features a complete redesign compared to the 16 Pro Max, with a large aluminum unibody coupled with a small "Ceramic Shield" glass pane underneath the enlarged camera "plateau." Similar to the last two generations, it has an Action button at the top right edge and the Camera Control button near its bottom right corner. There's also an improved Ceramic Shield 2 glass on the screen that's more scratch-resistant.
Notably, the thermal system has been redesigned to have a vapor chamber to move heat from the new A19 Pro Chip into the aluminum unibody. The screen size remains the same as the previous generation at 6.9 inches, but the 17 Pro Max has better outdoor brightness and anti-reflection. The front camera has improved to be 18MP with a new "Center Stage" design for taking selfies. The rear cameras have all been upgraded to 48 MP Fusion. The optical-quality zoom now supports up to 8x (compared to the 16 Pro Max's 5x).
Unique solely to the iPhone 17 Pro Max is the option for up to 2 TB storage. It's available in Cosmic Orange, Deep Blue, and Silver and starts at $1,199.
Identification
You can identify the iPhone 17 Pro Max by the model number printed inside of the USB-C charge port.
  • A3257
  • A3525
  • A3526
  • A3527
You can also find the model number through the phone's UI by going to the Settings app and navigating to General > About. Tap on the number listed in the Model Number section and it should change to a format that looks like the numbers above.
Additionally, Apple offers a quick online tool to help identify your devices: Identify your iPhone model.
The iPhone 17 Pro Max features a 6.9-inch (diagonal) flat glass screen, thin black bezels, a pill-shaped, black "dynamic island" at the top of the screen, matte back glass with a glossy Apple logo, and aluminum side rails. It's camera "plateau" also reaches across the top left and top right edges of the backside of the phone. The 17 Pro Max has a small cutout for the Ceramic Shield glass pane underneath the rear cameras.
Volume controls and the Action Button can be found on the left edge, while the power button and Camera Control button are situated on the right. A rectangular camera "plateau" containing three cameras protrudes from the backside. This model has no home button.
The iPhone 17 Pro Max can be differentiated from the iPhone 17 Pro by its larger screen (relative to the 6.3-inch screen on the Pro model).
The iPhone 17 Pro Max can be differentiated from the previous generation iPhone 16 Pro Max by its much larger camera plateau and redesigned aluminum unibody with a with a small Ceramic Shield glass pane in place of an entirely glass back cover.
Technical Specifications
Dimensions: 16.43 × 78.0 × 8.75 mm (6.43 × 3.07 × 0.34 in)
Weight: 233 g (8.22 oz)
Water Resistance: IP68
Colors: Cosmic Orange, Deep Blue, or Silver
Operating System: iOS 26
Processor: A19 Pro chip
  • 6‑core CPU with 2 performance and 4 efficiency cores
  • 6‑core GPU with Neural Accelerators
  • 16‑core Neural Engine
  • Hardware‑accelerated ray tracing
RAM: 12 GB
Storage: 256 GB, 512 GB, 1 TB, or 2 TB
Battery: 5088 mAh on the eSIM models, up to 35 hours of video playback or 4,823 mAh on the physical SIM models with 33 hours of video playback
  • Qi2 wireless charging up to 25 W
  • MagSafe wireless charging up to 25 W
Ports: 1x USB-C connector
  • Charging
  • Reverse charging of accessories
  • DisplayPort
  • USB 3 data transfer (up to 10 Gb/s)
Display:
  • 6.9-inch “Super Retina XDR” OLED
  • Ceramic Shield 2 glass technology
  • Multi‑touch
  • Haptic Touch
  • 2868 × 1320 pixel resolution (460 ppi)
  • ProMotion adaptive refresh rate (1-120 Hz)
  • 2,000,000:1 contrast ratio (typical)
  • True Tone
  • P3 wide color gamut
  • 1000 nits max brightness, 1600 nits peak (HDR), 3000 nits peak (outdoor), 1 nit minimum
  • Fingerprint-resistant oleophobic coating
  • Dynamic Island
  • Anti-Reflective Coating
Pro camera system:
  • Main module
    • 48 MP "Fusion"
    • 24 mm, ƒ/1.78 aperture
    • Sensor-shift optical image stabilization (OIS)
    • Autofocus with 100% Focus Pixels
    • Enables 12 MP 2x optical-quality zoom
    • 4K120 video recording
  • Ultra-wide module
    • 48 MP "Fusion"
    • 13 mm, ƒ/2.2 aperture
    • Autofocus with Hybrid Focus Pixels
    • 120° field of view
  • Telephoto module
    • 48 MP "Fusion"
    • 100 mm (4x), ƒ/2.8 aperture
    • 3D sensor-shift optical image stabilization (OIS)
    • Enables 12 MP 8x optical-quality zoom
    • "Tetraprism" design
"Center Stage" selfie camera with Face ID:
  • 18 MP
  • ƒ/1.9 aperture
  • 4K60 video recording
  • Retina Flash
  • Ultra-stabilized video
  • Smart HDR 5
  • Dual Capture
  • 4K Dolby Vision video recording at 24 fps, 25 fps, 30 fps, or 60 fps
  • 1080p Dolby Vision video recording at 25 fps, 30 fps, or 60 fps
  • Cinematic mode up to 4K Dolby Vision at 30 fps
  • Slo-mo video support for 1080p at 120 fps
  • Time‑lapse video with stabilization
Sensors:
  • Face ID
  • LiDAR scanner
  • Barometer
  • High dynamic range gyro
  • High-G accelerometer (Crash Detection)
  • Proximity sensor
  • Dual ambient light sensors
Wireless Connectivity:
  • Apple N1 Wireless Networking Chip
  • 802.11be Wi‑Fi 7 with 2x2 MIMO
  • 5G, sub-6 GHz and mmWave (all models)
  • Gigabit LTE with 4x4 MIMO and LAA (all models)
  • Bluetooth
  • Second-generation Ultra Wideband chip
  • Thread networking technology
  • NFC with reader mode
  • Express Cards with power reserve
Additional Information
Author
with
Carsten Frauenheim
174,985 Reputation
442 Guides authored
iFixit Member of iFixit
Staff
119 Members
72,966 Guides authored
Past 24 Hours: 178
Past 7 Days: 1,158
Past 30 Days: 5,574
All Time: 143,657
